Intake Mods
nobody makes a spacer for the stock carby, the adapters we have are to put a weber carburettor on the stock manifold, as the base patterns are different, they just happen to be taller as well
just make one out of something solid like metal or maybe high density plastic. not wood
Edited by Super Jamie
thks that gives me an idea as I got a mech who makes spacer for from another car engine and adapt it into 4K engines
it is made of alluminium material :D
the spacers in all our photos are aluminium. i'd expect you could get a 50mm block of it for under us$50
after conversion it is around that price
what are the benefits of getting a carb spacer :D
I had one of these spacers too. I did exactly the same thing as Jamie to fit my DGV weber.
Lynx Corp makes them, and they can be purchased in most auto parts shops.
However mine was only 16-18mm. It also comes with bent studs and the casting of the adaptor plate allows for the bends.
Was your intended spacer plate for a Stock carby or aftermarket?
Lynx Corp
Just click on Carby Adaptors and Insulators ---> then carby adaptors.
Lynx Corp
looking for a spacer for my 4K Jap carb :D
