Intake Mods
an old performance trick, increases the plenum area, quite common on carbed v8s and stuff
i did the same thing with my weber adapter on my old 3k
hmmm A12 I have one in my Datto 1200 ute, As most people know i LOVE my fuel injection, i wont use carbies i hate them.
This weekend ive started making my EFI manifold for my A12 from scratch.
Short runners big plenum and a 70mm throttlebody, I'm looking for revs over torque. ill keep you all posted and put up some pics when ive got alittle more to show if people are intrested.
I know these are not Toyota or corolla, But it maybe information that can be use by others in the future.
If this does work ok ill be trying the same for my brothers KE70 as the 4KE manifold is not good for revs and the 7KE are just too hard to get and cost to much.
Edited by NickZ
you can also make up a spacer out of several stock carby pcv plates. you'd need longer studs in the manifold, and it would be an idea to make up a gasket for each and permatex it in. and of course, block off the pcv hole
i had a stack of them i'd epoxied up the holes in and was making gaskets to go between them, then i got a pair of sprinter twins, then rob sold me those SUs :D
read some where are two main types of intake spacer
1. Open spacer
2. Inlet spacer
cannot recall the function any idea for the precise name :D
can I have the measurement for the thickness of the spacer plate
thks as interested to do one =)
unless you got a spare and willing to let it go for me :D
i don't own it anymore. from memory it was 45mm but i'm not certain
thks for the measurement as I plan to do a small spacer abt 40mm in depth open one :D
guys do let me know anyone of you are letting go your additional spacer as I am interested in getting one :D
