Ok guys
I was gonna keep it all hush hush but meh..f@$k that
OK the deal with my new motor is this:
ported 3K-C head (shaved only to make sure the head is flat...not to raise compression too much)
4K-C block - acid bathed - possibly shotpeened
60thou overbore
ACL pistons, rings, bearings
Lightened crankshaft - shotpeened
Lightened flywheel
5K con-rods
Reground cam (430thou intake lift, 400thou exhaust, 100-100 separation)
Possibly buying nicks 4-1 extractors and exhaust...
The intake is what I'm excited about
I'm getting a ford fairlane XD EFI manifold, Injectors, fuel rail and pump for next to nothing.
Manifold will be a custom jobbie.
EFI will be controlled by a MegaSquirt or similar. (I'm likening to megasquirt because of the hand controller :D)
probably a few other things in there I'm missing.
Hoping for 130hp (so I can eat excels and run 15sec quarters)
WOWWWWOWOOWOWOWOWOWOWOWOW
Man ure car already flys, u going to try and float as well?!!!!
God thats things gona be a beast!!
Eating x-els, oh thats gold ! :D
heheheh - i have to see this when its done... wow!!!
heya....sounds like some awesome bit of engine there.......we'll have to compare when i get mine up and running..:D :D.....
good god thats a fast rolla
ahhh, the power of rotory...
Still like urs tho - adleast it still will be driviable on the road :D !!
Just ran my plans through Dyno2000 and came up with
137hp @ 7500rpm without Nitrous on a street cam
187hp @ 7500rpm with nitrous on a street cam
142hp @ 7500rpm running methanol
hrmm...seems interesting :D
haha was just checking all my settings
found out I had a few things set wrong
max NA power is now
139hp @ 7500-8000rpm
before the bore was too small and the stroke was set wrong
