Nice one!
It drives nice as it is but yeah that will make her move.
Should go a little better with that setup. :blinks:
Charger FTW!
I think I might get me one of these... :blinks: HAHAHAHA
Nice Panelvan mate.
I like the 4agze idea. Would make a wicked little Panelvan to drive in. :blinks:
Keep us updated.
Josh :blinks:
thanks mate yah its awesome fun to cruise round in, one of my mates was very surprised thought it would get more body roll then it does.
I've been silently watching your thread, you and your dad seem to have some skill good luck with it.
got some parts in the mail today for the ADM 4agze, leaves me with just the pistons left,
so far the bill is $380 + $350 + $165 + $50
4agze fuel rail
4agze injectors, little bit dirty but the o-rings still look great, really happy with them.
also my sister bought a jeep wrangler 97 model, 4.0litre 4 cylinder heres my thoughts after the first drive
pros: awesome for 4x4
cons: mostly related to around town
heaps of body roll
horrible steering
slow, comparable to my 4k when I first got it - I had foot to the floor in the wrangler on a straight road in 4th
and I seriously think I couldn't get it over 80
you have to be crawling in third before it lets you into second
clutch has to be slammed to the floor before the car lets you turn it on
wondering how long its gonna be before she gets over it.
Edited by the_van_can
hay guys, check out my new part for my 4agze
I got a crank angle sensor :)
so I can run a coil pack, so I have an ems computer so I was looking at these
This coil is suitable for use with distributed ignitions and coil per cylinder ignitions. It is an inductive coil that is not recommended for CDI use.
so if anyone can confirm because I'm still new to this stuff, these should work fine I have no idea about cdi or anything.
They also have one that is a double ended coil setup to run wasted spark, once again something I'm not too farmiliar with.
so did some work to the car, car had leaking cam seals and cam cover seals, replaced those. Dizzy was leaking, bought the $22 rebuild kit from
kbox.ca and got a mate to rebuild it, he said it was a pain in the ass because I have the small port, way harder to get gear off and the bearing out.
check out the new fuel pump
its a re-labled bosche pump.
its an Audi 90 external fuel pump with vw logos on it got it from euro wreckers. it says made in france so it's only about 2-3 years old, its a new one.
car runs soooo good with descent pump, i was using a cheap chinese pump previously, and it was causing the lift pump before it to work hard out,
now my whole fuel system is quiet as. strongly recommend using descent fuel pumps no matter how broke.
  • 6 months later...
It's been a while since I've update,
Have been having all sorts of engine problems, have a new question in general mechanical section each week to try and fix them
as I am still learning alot and my mechanic mates help me with everything.
been having pcv issues that just don't make sense and leave mechanics scratching their head
but its fixed now motor NEVER blows smoke and always runs great,
fixed fuel delivery issues, fuel pumps dieing etc.
so anyway engine is always running great when it is running.
decided to upgrade the diff to a T series :)
also in the near futur I'm ugrading the fuel system so that I can get rid of the surge tank and lift pump
and go to a in-tank fuel pump. The fuel smell in the car is too dangerous to inhale, I will also need to weld up the holes I
drilled in the rear of the car for the fuel lines.
pulled old stocko diff out
pic from my phone of the new mounts
the new T-18 diff to go in, will require fair bit of modification, the coil spring stuff will have to be cut off
new and old diff
JDM AE86 tailshaft, hoping it will work not sure. I have 22 spline T-50 going to a t series so it SHOULD be perfect
also go my hands on a some AE86 gear for up front, struts, springs, JDM vented and slotted rotors, braided brake lines
everyone is going to think I'm mad but I have ultra low pedders springs or brand new king springs at stock 86 height, going to go with the stockies for now,
It suits me better to have a higher car, although I want to lower it so much because it would look awesome.
Nice dude :) I'm curious to see how you do the fuel system. i need to improve mine.
with the diff conversion you will have to used different/new U bolts for the axle because T series housings are thicker than s series. I used U bolts from a t series corona (rt104?)but i also had to grind the housing a bit to get them to fit snug. (the ra60 housing i used had a taper on it +slightly thicker than the corona t series)
sweet, thanks for the info, gathered I'd have to get different u-bolts. just can't wait to get it going again because my temporary car chugs the fuel, spent $63 on fuel in 5 days too and from work, need to get back to the 1.6 litre ftw.
so the old mounts have been cut off, and the new fabricated mounts have been tacked into place. It was waaayyy easier than I expected.
A mate that is experienced doing it helped me out and all we had to do was find the centre point of housing (width wise) and measure from
side to side a few things and just tacked it into place, then it's off to get tig welded. If you have the righr cutting disc you can grind
off the old mounts like butter.
  • 2 months later...
hows this thing coming man
yah been a bit slow been pretty bussy latly
this thing looks overrated seen it today at supercheap very very clean
thanks mate, re-did the fuel system still got a few issues I gotta fix, this might be up for sale in the future, need a more suitable car
this thing is soooo much fun to drive, its so hard to get rid of.
this is a cool car.
ive not seen this thread before, keep up the good work, will keep my eye open for updates!
i probably would have put that fuel system under the car (I'm not a fan of fuel inside the car), but hey if it works it works.
  • Upvote 1
