April 28, 201016 yr comment_433251 Is there much involved in replacing cv boots on an ae82, it's the only thing that got picked for a road worthy and also is the speedo electronic or cable as the dash is making a rattling noise and the speed jumping 20k but give it a little tap and it stops briefly and reads correct Report
April 28, 201016 yr comment_433265 Is there much involved in replacing cv boots on an ae82, it's the only thing that got picked for a road worthy and also is the speedo electronic or cable as the dash is making a rattling noise and the speed jumping 20k but give it a little tap and it stops briefly and reads correct No much at all, Only problem is getting the hub nut undone as they sometimes seize, Speedo is cable driven. Report
April 28, 201016 yr comment_433287 Is there much involved in replacing cv boots on an ae82, it's the only thing that got picked for a road worthy and also is the speedo electronic or cable as the dash is making a rattling noise and the speed jumping 20k but give it a little tap and it stops briefly and reads correct If your dash is rattling, the top plastic piece that sits over the cluster, pull out the 2 little air vents on the sides of the dash cluster, and check if the screws are loose, if not then take them out and 2 others above the speedo, they are on 45 deg angle at the back, take it off and put some thin foam tape on the back edge and it should fix your problem :) Report
April 30, 201016 yr Author comment_433633 Next problem is the proportioning valve for the washers. Hit the button for the front and it's fine but try the rear switch and it only sends water to the front. Valve seems to have direct power to the ignition circuit. Thoughts? Report
April 30, 201016 yr comment_433637 You checked to see if the valve is connected, Alot of them are bypassed as they fail, You are more then welcome to try one of mine. What do you mean direct power to ignition? Report
April 30, 201016 yr Author comment_433665 i got 2 others from the wreckers this arvo. turn the key to on and it has power to it. i will probably figure this out when i've had some more sleep Edited April 30, 201016 yr by LowVp Report
May 1, 201016 yr Author comment_433872 No luck with the switch, tried another switch and solenoids to no avail Report
May 1, 201016 yr comment_433909 So you replaced the rear switch and it still didn't do anything? I will have a look at mine tomorrow and see what I can work out. Report
