hey guys. i bought a ae95r a little while ago.
ok I'm sick of changing this post when ever something new arises. so now its simply my i need help and keepin people upto date on the wagon thread...
any help will be greatly appreciated
daniel
Edited by delaney
hey guys. i bought a ae95r a couple weeks ago
i need help trying to get my speedo needle to sit on ZERO again, its currently all the way down on thew stopper underneath. Pull the cluster apart and reset the needle in the right place. It just pulls off.
will a drivers front gaurd from a 92seca fit my 95r. Yes
i need the PCD sizing for the wheels so i can look for a set of 15s. 4x100+38-45
is there any chance i can get coil overs to fit the front end to give it a bit niocer ride height and better grip on twisties They exist, but may be hard to get. Probably easier (and cheaper) to get a set of kings or lovells springs and a MATCHING set of shorter stroke strut inserts and rear shocks
daniel
my power steer pump is noisy.
just curious as to what the two vacumn lines on bottom of the pump are for??
could i put a pump off a 92 seca onto it, even if the new one does not have the vacumn lines
Is that for the pump on the motor driven by the fan belt ? Or the thing on the steering rack ?
The vacuum lines on the steering rack are there so that, basically, the more vacuum the motor sees (ie the faster your going) the less power assist you'll get on the steering.
At least thats where the vacuum lines are on the ae82 - at the steering rack.
the one running off the belt... is gettin worse, but i do enjoy the whinge... i think i need a GZE :yes:
i unhooked them last night and made no difference but i don't know what they do so i put them back on
Vac lines on the steering rack are for engine idle up for idle speed steering, Work the same as the accessory VSV.
Check to see if you have enough fluid in the reservoir.
Edited by Trev
res fluid is fine. i flushed it out hoping that fresh fluid would bring it back to life.... but no still noisy.
the lines i speak of are on the bottom of the pump, what are they for....
all my older cars never had power steer, so these vac lines on pump are confusing me
  • 4 weeks later...
thanks womble, but i manged to guess and get the hoses right on weekend.
all seems to be good, and i don't have any wet carpet atm. all i can think of , is the car has been in the NT its entire life and somebody undone them just coz they can
being given a set of 98 WRX frint bucket seats.
now my issue is.
how hard to fit?
yes i no ill need engineering, but willl it need to be done as soon as the seats are mounted ????
