Re-installing Rear Panhard Rod After Replaceing Bushes
Howdy guys, trying to install my panhard rod, replaced the bushes.
The end which connects to the diff, I'm having troubles knocking back on all the way.
I've lubed it up with some rp7, and can get is so far as the thread is level with the busher, but no further....is there a good trick???
Thanks!
Edited by ke71-rolla
got it in the end, just had to have the guts to lie all the way under the car :jamie:
By the way, don't tighten the bolts right up until you get the car back on the ground.
Yup, The bushes will twist when you lower it if you tighten them when its in the air.
I got it to finger tightness, then re tightened it once it was lowered; that sound about right?
hahah, goodo had a feeling it was best to do it like that
