ca18ae71 Posted June 2, 2010 Report Share Posted June 2, 2010 (edited) tryed to start the rolla to move it for paint , now i have no spark at the plugs , i do have power to the coil and its earthed, Edited June 2, 2010 by ca18ae71 Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted June 2, 2010 Report Share Posted June 2, 2010 wats been changed since last time you started it? does it crank? Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 2, 2010 Author Report Share Posted June 2, 2010 wats been changed since last time you started it?does it crank? yeah it will crank but not fire, umm pll milked the fuel and stole some shit out of it , Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 3, 2010 Author Report Share Posted June 3, 2010 i give up lol , Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted June 3, 2010 Report Share Posted June 3, 2010 ignitor? is this the 4a with individual coil packs or does it have a dizzy? do you have spark leading away from the lead from the coil? Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 3, 2010 Author Report Share Posted June 3, 2010 4age 16v , with dizzy , i have 12+ at the coil but none from there on woulds Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted June 3, 2010 Report Share Posted June 3, 2010 try another coil then can only go through the steps and try and eliminate the problems. Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 3, 2010 Author Report Share Posted June 3, 2010 can i use any coil ?? Quote Link to comment Share on other sites More sharing options...
greenmac80 Posted June 3, 2010 Report Share Posted June 3, 2010 hmmm you would have to use a coil that is used in conjunction with an ignitor. non ignited coils are different. Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 21, 2010 Author Report Share Posted June 21, 2010 pretty sure my ignitior is dead is there a special way to check them Quote Link to comment Share on other sites More sharing options...
Trev Posted June 21, 2010 Report Share Posted June 21, 2010 Try another one, I might have one around here somewhere. Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 21, 2010 Author Report Share Posted June 21, 2010 i just found one , van can had a ignitior and coil pack Quote Link to comment Share on other sites More sharing options...
ca18ae71 Posted June 23, 2010 Author Report Share Posted June 23, 2010 ok i tryed a new coil and ignitior, nothing i have know idea whats going on Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted June 23, 2010 Report Share Posted June 23, 2010 ok i tryed a new coil and ignitior, nothing i have know idea whats going on Did they put any crud in the fuel when they fked with it? Have you tested the lead that runs from the centre of the dizzy to the coil? Did it conduct? Quote Link to comment Share on other sites More sharing options...
Trev Posted June 23, 2010 Report Share Posted June 23, 2010 I really dunno where to start as you aren't too sure what has been done, Check to see if the ecu has power and that the brake light fuse is still in the holder, If you weren't like 3 hours away I would come have a look. Quote Link to comment Share on other sites More sharing options...
