5k Cam
want to get a cam for the 5k. want it to idle all grumpy an go better than it already does. do i.....
1.buy a lumpy cam
2.take the 1 out of it and get wotever it takes to make it grumpy
Which 1 am i better of to do and what cost am i looking at??
also can i jus get the carb jetted or do i need a bigger 1?
have a couple of nikki carbs sitting on rotary motors in the shed. will they be too much???
cheers
yea take it out and take it to a cam regrinder
question's to ask your self
do you want low end torque?
mid range
or all your power up top?
Also ask yourself do I have hydrilic lifters and do you want to change them to solids as this woll determine the cam grinds you can get.
Personally I stuck with the hydrolic lifters and had my cam reground to Wade 169 specs. Noticable lump at idle, but not excessive and a good spread of power. Would spin to 8000 rpm as well.
Could of gone bigger, but it would of made it a pig to drive and slower overall.
want low range :)
for skids and really want it to have that lumpy idle sound to it.
what is this wade 169 specs you speak of??
use the search function it has been repeated a couple time now..
want low range :laff:
You seem more interesting it what it sounds like at idle than what it'll go like so just remove 1x spark plug lead. :lolcry:
Seriously, there's several fresh thread about K cams lately. Go look in one of them. :)
