Change Courtesy Light?
Got a 1997 Corolla and the courtesy light stopped working. Popped off the cover and this was the first time ive seen this kind of bulb. The bulb seems to be riveted on a aluminum rod and onto the plastic housing. I wouldn't have a clue how to remove it. Didnt want to have a crack at getting it off at the fear of buggering up the aluminum rod because obviously its needed to change between door, off and on.
Anyones help is appreciated.
I might be able to help, if you take a picture of it
97 Corolla? As in an AE101/102? If so, then the courtesy lamp is a festoon bulb that sits between two spring-clips, it should just pop straight out. If it gives you trouble, then just unscrew the whole assembly (two screws), disconnect the wiring plug and that should make things heaps easier.
If that doesn't sound right, take a photo of it and we should be able to work it out.
It's a 102
Here's a picture....
What needs to be replaced? Is it just the bulb? Can they be bought from Supercheap etc? Never seen those bulbs before.
the globe in the middle?? Its the glass thing with little silver caps on each side, it just pops out. Take it to an auto place and they will you give a replacement
You can also get LED replacements from lots of different places, internet, specialist electronics stores on so on. They pop right in same as the bulb, cost pretty close to the same, use way less power and provide lots more light.
