hi all...
i have corolla ke35 1976..i wana change its engine....can i install toyota celica 3sgte 2000cc engine in my car or do u have any other suggestion....pls do tell me..
thanks.....
wow nice paint, is that Candy green?
now engines, how much can you do yourself? and are you a purist or can you settle with any make of engine other than Toyota?
Edited by Sam_Q
Isn't that an east/west engine?? So you would have the hassles of turning it 90deg?
How about the 3SGE from an Altezza, already north/south and will almost drop straight in.... get the whole engine & 6speed as a package.
3SGTE needs custom, intake, turbo manifold, sump and electronics, they never came out as a RWD motor. Some fit oil drains in the head, some don't. I've lowered the height of the center drain in my head on a 3SGE, hopefully that'll help the cause along side of an oversize sump. An AWD/FWD 3SGE/ 3SGTE to RWD is not a conversion for the faint hearted, as the other guys have said the beams 3SGE IS200 motor is the way to go, 150kw atmo, use 3SGTE forged rods and pistons and a nice size turbo and it'll make more power than you need. It's a superior motor over an SR20DET, but bang for buck its a hard call.
  • 3 months later...
How much power do you want? what do you use the car for? street, circuit racing, drag, drift?
how much can you afford to spend?
There are plenty of options. just to name a few common ones:
non turbo - 4age (16v and 20v), worked 5 or 7k, sr20de
turbo or supercharged - sr20det, 4agze, 3tgte, 5 or 7k turbos or supercharged.
All depends on your budget and goals. :)
Power...as much as that car can handle...maybe 250hp-300hp
use..wana use for every race...
and no worries of budget....
i have found complete SR20DET with gear box..that's why i was saying of SR20DET....
That's probably the best bang for buck if the motor is good, and cheap.
Being old it might need a complete rebuild.
A couple of guys in Altezzaclub use the Beams 3SGE in other cars, AE86 or Celicas or KE70..
The 8000rpm straight out of the factory is quite an attaction... :rolls:
