hey guys
i just got hold of a k-t bell housing and a new motor.
i have it all sitting in the car. but the g/box crossmember doesnt line up with and holes in the car
is there a certain gbox mout i have to use or do i have to make a custom one?
cheers Ryan
Just slot the holes in the one you've got 5-10mm and you'll be apples. :( :D Or maybe that was to line up with the second set of holes in a 30/55. how far off are they?
Oh and cable or hydro? I'll add you to the "K-T rollcall" thread. :D
Edited by Taz_Rx
don't no if it helps but i had a ae71 cross member and the three holes for the gearbox mount where way off centre.
can't check how much as ive sold it,but defently way off centre.
rob
I am guessing you need a T50 crossmember, manual one too as the autos are different also.
Even though you have drilled for the rubber mount holes the gearbox mount position might be further forward/back from k50 to t50.
They only go one way, so as Taz Rx said turn it around.
I assume you are using a T50 crossmember as they are different?
The CM that came on my K-T50 was the same as a K40/50 one. Not sure if thats the " original" one though.
