T50 In Ke70 Problems
Just slot the holes in the one you've got 5-10mm and you'll be apples. :( :D Or maybe that was to line up with the second set of holes in a 30/55. how far off are they?
Oh and cable or hydro? I'll add you to the "K-T rollcall" thread. :D
Edited by Taz_Rx
They only go one way, so as Taz Rx said turn it around.
I assume you are using a T50 crossmember as they are different?
The CM that came on my K-T50 was the same as a K40/50 one. Not sure if thats the " original" one though.
