July 27, 201016 yr comment_454818 Toyota Norway have ditched their Ke1x partscatalogs :jamie: so would realy apreciate if anyone could post the partsnumber for the rear handbrakecable. Belive they are the same for both sides. May have a source for new ones if I had the number. Cheers, Tor. Report
July 27, 201016 yr comment_454897 Well Tor, this will crack you up. All KE1x's have the same cable setup. Left and right hand cables are identical (same part number). 46420-12011 BUT, there is also a different part number for Arctic climes, which I presume includes you! 46420-12030 I have no idea what the difference is, and the diagram doesn't illustrate it. Cheers and good luck. I would be stunned if you can get one through Toyota. By the way, are you interested in an all red KE17 tail light lens? Report
July 27, 201016 yr Author comment_454995 Thats great info Pete. No, Toyota isnt the source. They threw out stuff like this ages ago. Some parts however were rescued by a guy Ive been in contact with. All red (exept reverselight) lenses would look good but don't think they would pass roadworthy test. Especially if only one. Not 100% sure if both would pass.. Would however be very interested in a pair of decent chrome surrounds for them though.. Again, thanks - made my day Report
July 27, 201016 yr comment_455017 I have no idea what the difference is, and the diagram doesn't illustrate it. It would probably be just slightly longer as the cold climate will contract and shorten it. :jamie: Report
