August 11, 201016 yr comment_458543 just curious is it possible to put a V6 engine into ae82 sedan? if so what would be a good engine to put in? cos I'm on P's and not allowed turbos but would be a good sleeper too. Report
August 11, 201016 yr comment_458545 just curious is it possible to put a V6 engine into ae82 sedan? if so what would be a good engine to put in? cos I'm on P's and not allowed turbos but would be a good sleeper too. Anything is possible with the right fabrication but you also can't have engine conversions that were not available as a factory option for your vehicle. Report
August 11, 201016 yr comment_458548 can't put a v6 in a ae82 on your P's cause it requires a mod plate. Report
August 11, 201016 yr Author comment_458549 Anything is possible with the right fabrication but you also can't have engine conversions that were not available as a factory option for your vehicle. u sure? cos I'm pretty sure RB25/6 arnt a factory option for commodores lol Report
August 11, 201016 yr comment_458552 u sure? cos I'm pretty sure RB25/6 arnt a factory option for commodores lol Ha, you missed the point, YOU can't since you are on your p's. Report
August 11, 201016 yr comment_458553 Not sure you'd really want to. Unless of course, you want understeer into the first powerpole you come too. Report
August 11, 201016 yr comment_458554 Ha, you missed the point, YOU can't since you are on your p's. Exactly you aren't aloud any engine mods that require a mod plate, otherwise id be putting a bigger engine into my T18. Not sure you'd really want to. Unless of course, you want understeer into the first powerpole you come too. Even the old v6 Camry's we get in for servicing at work under steer bad and in also have bad torque steer, but surprisingly the aurions have nearly no torque steer apparently because of the thicker cv for the longer side. Edited August 11, 201016 yr by 19914afc Report
August 11, 201016 yr comment_458572 i'm not sure you could even get club rego for that shit.... u sure? cos I'm pretty sure RB25/6 arnt a factory option for commodores lol well in the VL the RB motor was standard also in turbo, so effectively the 25/26 motors just carried a small bore/stroke. Edited August 11, 201016 yr by GJM85 Report
August 11, 201016 yr comment_458579 Exactly you aren't aloud any engine mods that require a mod plate, otherwise id be putting a bigger engine into my T18. Even the old v6 Camry's we get in for servicing at work under steer bad and in also have bad torque steer, but surprisingly the aurions have nearly no torque steer apparently because of the thicker cv for the longer side. How can you say that Aurions have no torque steer? They are well known for it. If you want a FWD V6 buy a 20 series manual V6. They go well for what they are. Report
August 11, 201016 yr comment_458589 well compared to some of the other cars they don't have as much. Report
August 11, 201016 yr comment_458603 The v6 out of the mitsubishi fto could be interesting. Or the early Eunos 300 Both 2 litres i think and love to rev. don't know why anyone would bother but definately be different Report
August 11, 201016 yr comment_458606 The car would require a blue plate, and you would still not be allowed to drive it on your P's in Qld. Masturbating with a cheese grater is also different, but not recommended. A lot like cramming a V6 into an 82. Edited August 11, 201016 yr by Redwarf Report
August 11, 201016 yr comment_458608 Masturbating with a cheese grater is also different, but not recommended. that is some funny shit.... i nearly spat my woody. Report
August 11, 201016 yr comment_458611 I'm on P's and not allowed turbos but would be a good sleeper too. you also can't have engine conversions that were not available as a factory option for your vehicle. The car would require a blue plate, and you would still not be allowed to drive it on your P's in Qld. :dance: Report
August 11, 201016 yr comment_458612 that is some funny shit.... i nearly spat my woody. Did you swallow the woody? :dance: Report
