Drives great ,with the 5k even with the low compression off boost (2500 rpm) would be just like a NA 4k .With boost very different .The supercharged 4k had a lot of torque down low ,but this is very similar .Often go around corners in 3rd,4th gear & just accelerate away as if it was in 2nd .Have to be careful if the road is wet it will spin in every gear inc 5th if you accelerate too hard .
  • 2 years later...
