Hey just wondering if someone could point in the right direction on what i would need to swap my 3tc carbed setup to an efi I'm looking for the cheapest easiest way to do this i was told there is an intake manifold that will go right on just don't know what off of all help would be greatly appreciated thank.
Edited by 80ke70
Easiest and cheapest way would be to get a weber adapter plate and use the EFI system off the first EFI falcon as then you can use the stock manifold.
Oh an which adapter plate would i need? an as far as years what year was the first gen talons? sorry about all the questions always been a carb guy wanting to try somthing different.
to be honest i woudlnt be bothering with the ecu/wiring from a falcon. falcon = ~3L, 3tc = 1.8L, its never going to run properly, if at all.
get the EFI plate thing, with the injectors and then pick up a cheap megasquirt ecu;) make a new loom (maybe get the falcon loom to get the plugs off). and then start tuning.
