September 13, 201016 yr comment_468249 yeah, stick with the hydros. The are good for 8000rpm so why bother changing Report
September 13, 201016 yr comment_468254 4k/5k is the same. 3k has different stud patterns. 7K's are wider. Report
September 13, 201016 yr comment_468255 I was under the impression this was not possible? The 5K sump is slightly wider, it doesn't fit... I haven't actually tried this myself so I could be wrong. Certainly is possible, I've got a 4k sump on my 5k. 4k and 5k ones are identicle (unless its the above pictured 5k one), 3k sumps are a bit different and can't be used on a 4/5k. They're slightly deeper and use 2x less bolts per side to bolt on. :wink: Report
September 13, 201016 yr comment_468259 Thanks guys, learnded me something new today :lol: 3K sump on 5K, no. 4K sump on 5K, yes. :) Report
September 13, 201016 yr comment_468273 the 4k sump I had fit straight on, no problems. the lower section is shorter. so as to clear the main cross member. my pistons are ACL standard replacements. not bad quality at all. Des I got my 5k full rebuild kit for $480 through beenleigh bearings and a double row timing kit for $135. worth every cent. Taz_Rx - I'm having my pushrods shortened to save on cash. Thankfully my dad's got the skills. Edited September 13, 201016 yr by GJM85 Report
September 13, 201016 yr Author comment_468327 the 4k sump I had fit straight on, no problems. the lower section is shorter. so as to clear the main cross member. my pistons are ACL standard replacements. not bad quality at all. Des I got my 5k full rebuild kit for $480 through beenleigh bearings and a double row timing kit for $135. worth every cent. Taz_Rx - I'm having my pushrods shortened to save on cash. Thankfully my dad's got the skills. A place near me is quoting me up some bits tomorrow so i'll see how they go but i reckon $480 is hard to beat. Whats in the ACL kit and what brand is the timing chain kit ? Report
September 13, 201016 yr comment_468351 A place near me is quoting me up some bits tomorrow so i'll see how they go but i reckon $480 is hard to beat. Whats in the ACL kit and what brand is the timing chain kit ? the ACL rebuild kit came with all bearings and thrust washers, gaskets, pistons and rings. no timing gear other than gaskets. I had the reco shop 3 way seat and grind my valves. make sure you check the diameter of your crank mains. the crankshaft had slipped a bigend bearing previously and had obviously been machined. standard bearings were too small. luckily i had a spare crankshaft.... Can't remember the brand of the timing kit but it was along the lines of SUPER RACE!!! :cool: Edited September 13, 201016 yr by GJM85 Report
September 13, 201016 yr Author comment_468353 the ACL rebuild kit came with all bearings and thrust washers, gaskets, pistons and rings. no timing gear other than gaskets. I had the reco shop 3 way seat and grind my valves. make sure you check the diameter of your crank mains. the crankshaft had slipped a bigend bearing previously and had obviously been machined. standard bearings were too small. luckily i had a spare crankshaft.... Can't remember the brand of the timing kit but it was along the lines of SUPER RACE!!! :cool: Yeah i will send the head away after i have ported the exhaust ports. Report
September 13, 201016 yr comment_468365 From memory as bad as it is, i think the timing kit was 'power drive'. Report
September 14, 201016 yr Author comment_468776 A place near me is quoting me up some bits tomorrow so i'll see how they go but i reckon $480 is hard to beat. Whats in the ACL kit and what brand is the timing chain kit ? I was wrong, I was quoted $400 for the kit. Report
September 14, 201016 yr comment_468783 the 4k sump I had fit straight on, no problems. the lower section is shorter. so as to clear the main cross member. my pistons are ACL standard replacements. not bad quality at all. Des I got my 5k full rebuild kit for $480 through beenleigh bearings and a double row timing kit for $135. worth every cent. Taz_Rx - I'm having my pushrods shortened to save on cash. Thankfully my dad's got the skills. U can buy brand new pushrods threw crow cams just ring them up and say how long they are and the ends and theyll hook u up :) think its around $60 for a set Report
