Brake Booster
wondering if its possible to get boosters rebuilt but better? uprated or something?
or... what about bolt in replacements... don't worry about the MC jst the booster...
i reckon i remember reading somewhere on here about a subaru of some sort fitting?
any ideas??
found the info...
nissan pulsar gti-r booster is a direct bolt in... + the MC would be an awesome upgrade.
Mazda 121 bubble, early 90's model also a direct bolt up,
cheers phatke30!
wicked... i found today that kesev boosters fit ke30/55... also i know without a doubt that n14 pulsar boosters bolt in. also subaru liberty boosters are the same. just have a
different front spacing to suit different mc.. i'll have to look into the r33 thingo... that'd be a good combo.
something i need to ask though.. if you were to put this kinda combo.. the r33 one onto a 4k 5k etc. will there be enough vaccum to make it all operate properly?
So if you get an upgraded booster and mc do you need to upgrade the calipers and disks or will it still make a good improvement using stock brakes?
Calipers do the work so brakes can only be as good as the calipers. A bigger MC will push more fluid, so running a bigger MC with stock calipers is only going to give you a tighter pedal and increase your chances of lockups.
  • 7 months later...
sorry about the thread bumping from the dead.
mr greenmac80 - do have ke30 master or a ke55 square type?
is there anything that fits the square type master?
No idea mate there are plenty of booster that will fit the firewall i'd go with what ever mc will fit the booster.
Are ke30 and 55 firewall stud pattern the same? Cheers mate
