September 22, 201016 yr comment_470948 Soo.. When I purchased the car (AE92), only the drivers door opened with the key.. The key goes in and turns inside the passenger lock, but doesn't do anything.. If i rip it off, could it be something simple to play with at home or not worth fixing? Suggestions? I'm not good with this kind of thing and decided i'd ask here, seeing as you guys have probably pulled these cars apart a lot more than I have. Cheers :) Report
September 22, 201016 yr comment_470951 The mechanism rod has most likely fallen off or the clip on the back of the lock is not connected, pull the trim off and have a look. Report
September 22, 201016 yr Author comment_470954 Ahk i'll have a squiz tomorrow, a few other bits and pieces I want to inspect while the trim is off, so may as well. Thanks Trev Report
September 22, 201016 yr comment_470956 Hello, your lock may be ok,it may be the rod that goes from key lock to door lock mechanism.You will need to remove door trim to check if its connected.If it is connected,then its your key lock.While the door trim is removed you can unbolt the outer door handle and remove key lock and either change it for a new or second hand one or I have been told that a locksmith can fix/adjust the tumblers in key lock(then you can use the original key). Probably easier to change them with a new or second hand set.Seen some on ebay(new,I think)and they were quite cheap.They come with 2 door locks and an ignition lock(all the same key).Or get central locking fitted with remote button,and never worry about using a key. Think on the good side -- if you can't get in with a key,neither can a car thief!! In conclusion: I wouldn't worry about fixing it -- unless you are a gallant gentleman who frequently opens the car door for the lovely maidens !!! (lol). Report
September 22, 201016 yr Author comment_470962 Be nice to be able to open the door for the missus, and it's a piece of mind thing for me :) Report
September 23, 201016 yr comment_471064 So the clip on the back is not connected to the barrel? Report
September 23, 201016 yr Author comment_471083 Everything is connected.. Its inside the barrel that is frigged. Report
September 23, 201016 yr comment_471087 Everything is connected.. Its inside the barrel that is frigged. You don't know what I mean so ok. Report
September 27, 201016 yr comment_471883 I've got same sort of issue, but i put the key in lock on drivers side and it unlocks all doors except the passenger side, the misses isn't very happy as I have to lean across. If I unlock the door from passenger side with the key it unlocks though. Whats happening? Dried out? Report
September 30, 201016 yr comment_472542 I've got same sort of issue, but i put the key in lock on drivers side and it unlocks all doors except the passenger side, the misses isn't very happy as I have to lean across. If I unlock the door from passenger side with the key it unlocks though. Whats happening? Dried out? It sounds like your problem is central locking motor/actuator(or wiring).If you unlock the passenger side with key,does it open all doors? if you need a central locking mechanism and/or motor,give me a call 0413 960 696 I should have one somewhere...Thank you. Report
October 2, 201016 yr comment_472892 Buy a pair of matching locks from SuperAutoOne. My last pair were about $65. An easy quick and reasonable cheap fix. Smelly Report
October 2, 201016 yr comment_472965 Everything is connected.. Its inside the barrel that is frigged. If the key goes in and turns then it is not the cylinder. My money is on the little circlip on the back of the lock. It has either stretched or come off. Just make sure you inspect all the rods and even the little plastic bushings the rods sit in. They can slip out extremely easy if they are around the wrong way. I'll end my post by saying i play with locks for a living (Locksmith). Report
October 2, 201016 yr comment_472981 The mechanism rod has most likely fallen off or the clip on the back of the lock is not connected, pull the trim off and have a look. So the clip on the back is not connected to the barrel? If the key goes in and turns then it is not the cylinder. My money is on the little circlip on the back of the lock. It has either stretched or come off. Just make sure you inspect all the rods and even the little plastic bushings the rods sit in. They can slip out extremely easy if they are around the wrong way. I'll end my post by saying i play with locks for a living (Locksmith). This. Report
