October 14, 201016 yr comment_475443 Hi guys, i have a pair of ssr mesh wheels ( 14x6.5 i think) which i have flipped. I just want to know if there is any issues with running flipped wheels, I hae heard it can screw your wheel bearings etc.. Any advice or help appreciated thanks! Report
October 14, 201016 yr comment_475449 find out the offset of the wheels both flipped and unflipped, it all depends on the offset and also the design of the centre. and ill draw it up in solid works, and then we will see the dramas. you can measure wheel offset with a ruler. are you the same guy who asked this question on ae86dc? Report
October 18, 201016 yr comment_476449 I'm gonna go with above^^ The size of wheels you have, I'd be very much guessing that they are probably somewhere +10 to +20, which if reversed will make you have some stupid amount of negative offset. I don't know the correct mechanical way to word it, but think 'levers'. If you move the wheel further away from the hub (- offset), the forces from the weight of the car will be magnified thus causing stupid amounts of stress/wear on your bearings. Having the wheel sit closer (0 - + offset) will mean the forces are going to be more centred on the hub, thus no excessive wear on the bearings. Mightn't be 100% wording it, but in my head I can picture what I am trying to say :P Dave, the amount of times I have seen this question come up on forums, I really think you should put your mad engineering skills to use and definitely model something in Solidworks! Would sum everything up nice and fast, and be easily understandable :P Report
October 18, 201016 yr comment_476463 ...snaps stub axles off too! Too much leverage. Wheel, brakes, everything vanishes into the distance leaving you with a 3-wheeler! Some 1980s model of Honda Civic was quite prone to that- This is why there are laws as to how much you can widen wheels outside stock. Report
