November 22, 201015 yr comment_483806 gday guys... my 4k ke70 has been having some problems... it coughs and splutters like its got no pedi in it.. BUT IT DOES!!!! ive checked the firing order and its all correct... so please suggestions with that would be great... and also i recently put a brand new clutch in it a week ago and now its just starting to slip in 3rd gear.. does anyone know why it would be doing that?? i got a clutch kit when i bought it... some help would be appreciated if you could thanks... cheers morgzz Report
November 22, 201015 yr comment_483824 Did you get the flywheel machined before you put the new clutch in? Report
November 22, 201015 yr Author comment_483848 Check plugs. Also could maybe be a dead coil. it doesnt do it all the time thou.. Report
November 22, 201015 yr Author comment_483849 Did you get the flywheel machined before you put the new clutch in? nah i didnt taz.. still had meat on it Report
November 22, 201015 yr comment_483863 What's pedi?? The misfire- at idle? Under slight power/cruise? Under solid power accelerating? What's it like cold compared to hot? on over-run? Several times on a trip or once a day? Is there still free-play in the clutch cable? So long as the thrust bearing comes right off the pressure plate then you're up for pulling the box off again I'm afraid. Did you replace the pressure plate and clutch plate, or is the pressure plate worn out?? Edited November 22, 201015 yr by altezzaclub Report
November 22, 201015 yr Author comment_483864 What's pedi?? The misfire- at idle? Under slight power/cruise? Under solid power accelerating? What's it like cold compared to hot? on over-run? Several times on a trip or once a day? Is there still free-play in the clutch cable? So long as the thrust bearing comes right off the pressure plate then you're up for pulling the box off again I'm afraid. Did you replace the pressure plate and clutch plate, or is the pressure plate worn out?? pedi is petrol.. when it coughs and splutters it just cuts out, no matter how I'm driving.. sometimes it runs really well thou.. and yes, brand new pressure plate and clutch plate. and not much free play in the cable Report
November 22, 201015 yr comment_483865 Does it cough and splutter after it's heated up a bit? Can you tell us more about when it's doing what it's doing. Report
November 22, 201015 yr comment_483872 and yes, brand new pressure plate and clutch plate. and not much free play in the cable ...... which you just mated with a scored old flywheel. You should always machine the flywheel when fitting a new clutch kit. Report
November 23, 201015 yr Author comment_483882 i never drive it cold.. so its always warm when i drive it. it just does it out of the blue whenever it wants.. like the fuel cuts out or something but it doesnt Report
November 23, 201015 yr comment_483898 this is sounding suspiciously like the same issues I had with my coil. Losing power and spark, coughing and spluttering. Intermittent problem, huge difference one day to the next, sometimes all the way through the rev range, sometimes only under heavy load. try another coil. Report
November 23, 201015 yr Author comment_483933 leads are fair cooked.. i checked them at work today and the coil is fair old.. so ill replace them and get back to yas... philbey , your spot on in describing the problem.. howd you fix it?? Report
December 3, 201015 yr comment_485957 may also be the dwell angle and points. i had the same problem with my car, but then i bought new points and set the dwell angle and its fine now.. Report
