3K Un-Known Gearbox. Help Please
Noob question.. :bash:
Just wondering what's the easiest way to tell what 5 Speed gearbox it I have...
Fitted to a 3K which will narrow my search down I'm sure.
Cheers Jordy.
K50.
Or are you looking for what model it is out of?
Edited by SLO-030
Too easy cheers mate. Its just I read somewhere that it could be either a T50 or a K50.... obviously not.
How do i find out what model? or is it too much of a hassel? :hmm:
If the shifter is right at the back of the tail housing. its a KE70 gearbox.
If the shifter is about 6inches from the end of the tail housing, its a KE30/55 gearbox.
Sweet i'll check tomorrow.
Thanks.
Could be a T50 if the bellhousing can be seperated from (is bolted to) the gearbox
K50 bellhousings are cast onto gearboxes
Ok sweet i'll check tomorrow. Thanks for help.
Also an un-related question, seeing as you're a Moderator. How do i get a notification when someone replies to a topic i started or anything like that. I ticked all the settings but it still wont send me a notification unless I'm blind.
Seems to be a K50. Thanks.
And yeah email is correct, so through email that's where you get your notifications?
