hey guys and girls more mechanically minded than i, i have a bog stock 5k in my daily and it idles at just under 2000rpm i am wondering wtf is causing it to do it, i have tried turning the idle mixture screw out and to no avail it still idles at 2grand, i wouldn't mind the high idle if it had a really pissed off cam in it but it doesn't :( .
But the fuel bill hurts my wallet and it's thin enough as it is, so if you guys/girls could rack your brains and throw some ideas up to try to bring the idle down i'd be cheering :yes:
Cheers
Yeah bro the idle screw might help :P can't find my 5K carbie to take a pic :(
Slightly shorter acc cable or need adjusting?
Choke held open some how?
Edited by blzbub666
I reckon check all of the above. Id leave the mixture screws how the are and check the idle screw, make sure all of the vacuum hoses are connected and in the right spot. If you have moved the mixture screws already, wind them in then out and find roughly where the middle is, then you can tune it from there. Probably didnt help much, but thats where id be starting. Good luck.
Air leak? my car had a small air leak between the carb and the manifold and was idling high. Just get some carby cleaner and spray around the base of the carb and around the intake manifold and if the idle speed changes you may have an air leak, or you can do the same with water in a spray bottle. Otherwise sticky choke? throttle cable adjusted incorrectly?
I also had a AE92 with 4afc and the throttle shaft bush was stuffed and caused an air leak, so there are many things that could be making it idle high.
Edited by 19914afc
Evan - that sorta made sence but didn't at the same time :P ,
Reed - i think that helped alot, i'll be having a look at the carb tomorrow,
Phil - if i did that wtf would run my car??? Certainly not hopes and dreams, so thats a negatory there good buddy hahah
