December 15, 201015 yr comment_488401 i have really low oil pressure in my 3k.. when at idle its about 5, and at high revs 6000rpm+ its about 20-30. we have tried 3 types of oils in it. 25-50w, 10-14w, and sunthetic? or somnthing like that. motors only about 1 month old and around 2 hours running time. its just got pulled down and the bearings are fine. please help cheers Report
December 15, 201015 yr comment_488402 Were the thrust bearings and oil pump gears good? You could try shimming the bypass spring on the oil pump. Report
December 15, 201015 yr Author comment_488408 Were the thrust bearings and oil pump gears good? You could try shimming the bypass spring on the oil pump. I'm not to sure. what do you meen by shimming the bypass spring? i no what it is don't get what u meen by shimming haha Report
December 15, 201015 yr comment_488414 sump must be off/dissy removed. remove oil pump securing bolt (1 10mm bolt) remove the split pin SLOWLY spring will pop out with like a washer. all 3mm of spacers (washers smaller than 14mm wide if i remember correctly) push the spring in with the tip of long nose pliers insert the NEW split pin and wrap it around the oil pump HEY PRESTO Found this using the search function. Shimming means: http://en.wikipedia.org/wiki/Shim_%28spacer%29 Edited December 15, 201015 yr by eberbs Report
December 15, 201015 yr Author comment_488428 Oil pressure relief valve could be stuck open. yeah could be anything. the motors not here so can't really see those things. will be here staturday. what is ur presser at idle and high revs? in psi Report
December 15, 201015 yr Author comment_488510 Oil pressure light coming on or not connected? nah its not conneted it would be coming on thought.. orded a new oil pump today and put new crank bearings in. lets see how it goes i will be putting it in saturday morning and getting a new exhaust made up monday. Report
December 16, 201015 yr Author comment_488763 getting the car ready for murray bridge on the 30th? yeh boi Report
December 16, 201015 yr comment_488787 i had the same a low oil pressure problem with my motor, 9psi at idle and 40 psi at redline. turned out my engine builder left the timing chain tensioner loose :( thinnist oil for a k motor i would go is 10w40 Report
December 17, 201015 yr Author comment_488915 i had the same a low oil pressure problem with my motor, 9psi at idle and 40 psi at redline. turned out my engine builder left the timing chain tensioner loose :( thinnist oil for a k motor i would go is 10w40 ahhk bort some of that oil yesturday. oil pump came from auto and wrong onee :I Report
December 18, 201015 yr Author comment_489124 allright so just put it all back in and is around 60psi cold at around 2000rpm.. can't run it for to long as its got no exhaust, can someone tell me if 60psi is good? what do urs run at Report
