On the first day of the first month Gav said run....
......and it did.
Used the old 3k carby to run it in. Wired up the elctric dizzy, hooked up the heater hoses, put the 3k-b manifold and carby on and some gas in the tank. After a bit of turn over without the coil lead she fired straight up. It's angry. REAL ANGRY! :cool:
Edited by GJM85
Nice, that sounds awesome man!
Is the 3K-B manifold the twin carb one? I have one in the shed, but removed it from my 5K and put the single down draught Weber on.
Mine sounds very civilised compared to that!
uh did u run in the cam first before revving the living poo outta it?
sounds noice! good work mate
Yeah ran it for about a 20 minutes on full choke. Not entirely sure what rpm she was sitting at but with open extractors I had to leave the shed. My ears were ringing. Then we set the rockers and did it again. No smoke, no smell. She's fresh, real fresh!
It's just the single manifold Zoidy. Just the single.
Edited by GJM85
Bugger me!
I had the volume up full because I couldn't hear anything, then it started!
Sounds nice and angry, and loud. :yes:
What internal work have you done?
Bugger me!
Standard bottom end, acl pistons and rebuild kit, power drive twin timing kit, holden solid lifters, aftermarker datsun pushrods, big Tighe 104 cam, ported and polished 4k head, 4k valves and rocker gear with 5k valve springs & shimmed oil pump. That's all i can think of for now.
