February 2, 201115 yr comment_500142 hey guys just wondering does any one know if i put twin 40mm dcoe webbers on my 4k will it start with out a choke?? thanks :) Report
February 2, 201115 yr comment_500152 never used the choke with my 5k fitted with 3k-b carbies so I guess twin webbers would be similar Edited February 2, 201115 yr by coln72 Report
February 2, 201115 yr comment_500162 Pump the throttle a couple times, then hold it down a little bit when you hit the key Report
February 2, 201115 yr comment_500179 Pump the throttle a couple times, then hold it down a little bit when you hit the key mine had troubles ideling,conecting my choke and giving it a tune was what got mine running :yes: Report
February 2, 201115 yr comment_500280 I occasionally need the choke for the twin SUs on my 7k (usually just if it hasn't been started in a couple of days/weeks). Report
February 2, 201115 yr comment_500322 I'm running twin dellortos on my 5K without a choke. When it's warm it ususally fires first hit. In cold weather it takes a couple more seconds to crank with a quick pump or two of the throttle while cranking. Apart from that, it's never really given any trouble. It will run a little shit for a minute or two on cold days, occasionally stalling, but all in all it's easy to start. BUT - mine has been properly tuned, on the dyno. If you're just slapping them on without a pro tune, then be prepared for all sort of shitty times. Report
February 2, 201115 yr comment_500330 The choke setup will make it easier, but Webers will shoot twin jets of fuel right across the garage when you pump them. A couple of pumps then hit the starter, and you'll have to use your right foot to make it idle until it warms up. Its not that hard to do the conversion properly and fit a choke cable. Philbey is right, you will need to sort out exactly which jets and emulsion tubes suit the motor best. Lots on the web about solving misfires and poor performance with jets. Report
February 3, 201115 yr comment_500541 All the Webered cars that I've driven haven't needed a choke. Same again, a couple of pumps and then start. Report
