Is A 5K Worth The Time?
Hey guys, does anyone know how much of a difference a 5k will make potential wise and preformence wise? Or should I just spend the money on "beefing" up the 4k?
Help always apprecitated :y:
  • Replies 31
  • Views 16k
from what i gather
Spend the money beefing up a 5k and you'll have a zippy little run about
EDIT- 5k is a much better platform to start from rather then a 4k
Edited by Mason.
A 5k is good money spent If you putting a lot of money into a K engine, if you going to put it in and change the carby some might say its not really worth the effort and time. not much top end difference from the 4k but more torque ar the bottom!
my worked 4k keeps up with a bog stock 5k (he had a passanger aswell)
5k = no clutch kicking in the wet
Edited by Evan G
okay, might go for a 5k then... Whats a healthy figure you can get out of them and have some fun with? I'm not after 48235028rwkw i just want a nice sounding rolla with some rain drifting power hahaha :lolcry:
theres a fella in tas with a 5k with twin side drafts, cam. pulled 66rwkw
With some usual intake cam and exhaust mods and a little
extra comp I would expect to see somewhere around
90hp at the treads
How much would that cost? sounds good to me
depends how mechanically retarded you are? your looking around the 1800 mark if a engine rebuilder has to do all the work, all you do is drop it off and tell him what you want and bend over.
i have a 5k in my corolla. its completely stock and i can chirp 2nd gear pretty well.
I'm getting extractors and webbers for it later on and probably make a straight through exhaust.
but from the power output I'm getting in the wet should kick out no problems.
yea a bog stock 3k with a HD clutch would chirp 2nd :glare:
"bog stock" dead standard
