stable20 Posted March 14, 2011 Report Share Posted March 14, 2011 hey guys, i have a problem with my 5k motor in my ke70. it seems to be verry jumpy and does not idle nicely. i was thinking that the valve springs may be soft.? if any one could give me some direction on this that would be great. Quote Link to comment Share on other sites More sharing options...
GJM85 Posted March 14, 2011 Report Share Posted March 14, 2011 smoke? Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 no smoke at all, its running rich though with the fuel. replacing 5k carb with 4k Quote Link to comment Share on other sites More sharing options...
Twinky Posted March 14, 2011 Report Share Posted March 14, 2011 Could be an air leak. Check all vac lines and manifolds. Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 yeah the exhaust manifold has a leak getting fixed this week with extractors and full exhaust system. but could this be the main problem. as i said before could soft valve springs be the issue? Quote Link to comment Share on other sites More sharing options...
Evan G Posted March 14, 2011 Report Share Posted March 14, 2011 could be a burnt valve or something but deff not a valve spring problem. check the timing/air leaks? etc etc Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 timing is fine. after the exhaust manifold is fixed, anything suggested after this? apart from conversion :P Quote Link to comment Share on other sites More sharing options...
coln72 Posted March 14, 2011 Report Share Posted March 14, 2011 stuck needle and seat???? Give the top of the carby a whack with the handle of a screw driver. Or swap 2 and 3 plug leads, remove aircleaner, hold foot flat and pump the key for a few revs. Should backfire up through the carby and remove any shit that may be in it. Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 stuck needle and seat???? Give the top of the carby a whack with the handle of a screw driver. Or swap 2 and 3 plug leads, remove aircleaner, hold foot flat and pump the key for a few revs. Should backfire up through the carby and remove any shit that may be in it. smartt :) i will give all these options a go. i was kinda hopeing i would have to take the head of so i could get some head work done to it. thanks for your inputs guys. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted March 14, 2011 Report Share Posted March 14, 2011 If its only at idle it will be a tuning issue- Do a compression test to check inside the cylinders. It can't be both of these- its running rich though Could be an air leak. Why not fit a Weber to suit the exhaust and get a cam cut? Make sure the studs and bolts are all cleaned and sized, and the extractor manifold is the same thickness as the inlet or you will have stripped threads and leaks forever. Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 (edited) I'm just a bit tight on money at the moment. the extractors are to suite k motors. Edited March 14, 2011 by stable20 Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted March 14, 2011 Report Share Posted March 14, 2011 the extractors are to suite k motors. Ah, but they don't! Check out the photos halfway down the page- Flange thickness wrong, welds in the way, pipes don't match the ports... http://www.rollaclub.com/board/topic/42407-the-girls-ke70/page__p__445727__fromsearch__1#entry445727 You have to check everything if you want it right. Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 14, 2011 Author Report Share Posted March 14, 2011 (edited) Ah, but they don't! Check out the photos halfway down the page- Flange thickness wrong, welds in the way, pipes don't match the ports... http://www.rollaclub.com/board/topic/42407-the-girls-ke70/page__p__445727__fromsearch__1#entry445727 You have to check everything if you want it right. so i might have to do some mods to the extractors to suit properly? why wouldnt they just bring them out to bolt straight on, some people like making it hard for others haha. Edited March 14, 2011 by stable20 Quote Link to comment Share on other sites More sharing options...
philbey Posted March 14, 2011 Report Share Posted March 14, 2011 It's just not that easy, lasercut steel plate comes in set sizes, the flanges on the inlet manifolds can inevitably vary as they are cast. They've made it as easy as possible by making the extractor flange thinner than the factory flanges, it would be a whole lot harder if it were the other way around. Quote Link to comment Share on other sites More sharing options...
stable20 Posted March 15, 2011 Author Report Share Posted March 15, 2011 It's just not that easy, lasercut steel plate comes in set sizes, the flanges on the inlet manifolds can inevitably vary as they are cast. They've made it as easy as possible by making the extractor flange thinner than the factory flanges, it would be a whole lot harder if it were the other way around. i see, thanks. Quote Link to comment Share on other sites More sharing options...
