Quick question, I was wondering if I put the battery from my s1 Rx7 into my ke30 (don't know what each battery are but can look) will I blow any fuses or anything break etc. or should i be fine?
Edited by FOOMAN
Make sure the terminal sizes match your clamps ( or factor in that you may need to change those)
I thought it was the red wire......woops!
Cheers parrot, it's not going to be permanent, just long enough to see if my alternator is gone in the ke30, ill sus out the terminal sizes though
