parrot Posted May 8, 2011 Report Share Posted May 8, 2011 It's never that simple. There are always differences. I haven't done that swap, but if I were you, I would be replacing the existing motor with another exactly the same. Quote Link to comment Share on other sites More sharing options...
GJM85 Posted May 8, 2011 Report Share Posted May 8, 2011 It's never that simple. There are always differences. I haven't done that swap, but if I were you, I would be replacing the existing motor with another exactly the same. THe only hard part is the lume. What to use and what not to use.... Quote Link to comment Share on other sites More sharing options...
basher_ke20 Posted May 8, 2011 Report Share Posted May 8, 2011 (edited) Just an afterthought, could I use a 4A-FC (and swap intake manifold and sensors) to replace the 4A-FE in the car? Thanks. as the fuel pump is a lift type in the head of the 4afc and the 4afe uses an in tank pump you can't just swap the manifolds over as the heads are different. the blocks are the same but the heads are different on the inlet side. hope this helps chris Edited May 8, 2011 by basher_ke20 Quote Link to comment Share on other sites More sharing options...
Bodge Posted May 8, 2011 Author Report Share Posted May 8, 2011 Thanks heaps. Now the hunt is on, haven't managed to find one yet. Cheers. Quote Link to comment Share on other sites More sharing options...
