Fixing A Mate'S Nova
Apologies for my lack of research, A young Irish bloke I work with had his '91 Nova stolen and the motor is now toast.
I have volunteered to swap over another one but am not familiar with Rollas at all.
He knows it is a 16 valve motor but that is about all.
What engine would it have (assuming it is stock)? I am expecting a pic of the engine bay via email soon.
What should I get him to check to be certain? I am sure he knows squat about cars...
I have seen a 4AGE? for sale with box/loom/ecu, would it run the same drive shafts as what he already has and would the full conversion be worth the stress?
Sorry again for not fully researching, but hell it ain't my car and I'll be helping out the lad for free.
Cheers all.
Cheers all.
The nova's came with either the 4AFE or the 4AGE I beleve, should be able to take one from a 88-92 corolla sedan or sr5. If its a 4AGE a 88-92 Corolla GTS or MR2 would have it.
if its a nova it wont be a 4age. it will be a 2afc, 4afc or a 4afe. these should be a little cheaper to buy as its not really known as a performance motor.
hope this helps
chris
hope this helps
chris
Wiki
Also called Geo Prizm
Toyota Sprinter
Toyota Corolla Seca
Production 1989–1992
Body style 4-door sedan
5-door hatchback
Engine 1.6 L 4A-FE I4
1.6 L 4A-GE I4, 105 hp (78 kW)
1.6 L 4A-GE I4, 130 hp (97 kW)
Transmission 5-speed manual
3-speed automatic
4-speed automatic
Wheelbase 95.7 in (2,431 mm)
Length 170.7 in (4,336 mm)
Width 65.2 in (1,656 mm)
Height 52.4 in (1,331 mm)
Related Toyota Corolla
Toyota Sprinter
Toyota Celica
Toyota Paseo
Toyota Tercel
Holden Nova
Thanks for the replies.
So if will be 4A-FE or 4A-GE then. Most likely to be 4A-FE though it seems.
Do they run the same ecu/loom? Couldn't be that lucky could I?
Cheers again.
Edited by Bodge
Cheers again.
Nope :)
Luckily, 4AFE's aren't exactly rare. Only thing you need to confirm is whether its carby or EFI. I think '91 was the changeover year.
hope this helps
chris
Nova's didn't have the 2A, they had the 6AFC. They also (depending on the year) ran the 7AFE too.
ok so basically i was making the point that they don't come with 4age from factory, and i have seen a 2afc in one at work.
No 2afc and the Nova was released with the 6AFC, 4AF* and the 7AFE.
I'm pretty confident that it is a 4A-FE now.
Thanks for the input.
Now to find one!
Cheers.
No such thing as a 2AFC anyway, they only ever had the SOHC head.
Yep
must be thinking of a 2ac from a ae82. least we have established the motor now and shouldnt be too dear for you
Just an afterthought, could I use a 4A-FC (and swap intake manifold and sensors) to replace the 4A-FE in the car?
Thanks.
Edited by Bodge
