May 8, 201115 yr comment_522634 It's never that simple. There are always differences. I haven't done that swap, but if I were you, I would be replacing the existing motor with another exactly the same. Report
May 8, 201115 yr comment_522649 It's never that simple. There are always differences. I haven't done that swap, but if I were you, I would be replacing the existing motor with another exactly the same. THe only hard part is the lume. What to use and what not to use.... Report
May 8, 201115 yr comment_522651 Just an afterthought, could I use a 4A-FC (and swap intake manifold and sensors) to replace the 4A-FE in the car? Thanks. as the fuel pump is a lift type in the head of the 4afc and the 4afe uses an in tank pump you can't just swap the manifolds over as the heads are different. the blocks are the same but the heads are different on the inlet side. hope this helps chris Edited May 8, 201115 yr by basher_ke20 Report
May 8, 201115 yr Author comment_522666 Thanks heaps. Now the hunt is on, haven't managed to find one yet. Cheers. Report
