so my ae93 gti had a leaking welsh plug
just removed it and i'm deciding to replace the others at the front of the motor too
should i do it while i'm there or just leave them?
they don't look corroded at all but should i replace them or not?
in my opinion if they aren't broken don't fix them!
just make sure you check them out make sure they aren't leaking or aren't corroded etc.
give them a good clean so you can see them properly etc.
If your already there do them all,if ones gone chances are they are nearly all due to be done.Just because they look alright
on the out side accounts for nothing.
The engine may have been run for years with out coolant hence corosion etc
rob
yeah i was tossing it up but ended up leaving them
the car only has to last a couple of years and i've got another car so it can be off the road again
would have like to do them all but i couldn't be bothered at the time
