June 10, 201115 yr comment_530939 Hi everyone i don't wanna ask a question that problem has been answered...soo can someone link me to a "how to 4k headgasket" i couldnt find any :( Report
June 10, 201115 yr comment_530941 there is a copper bit that has to line up with a oil hole in the block Report
June 10, 201115 yr comment_530952 Which bit couldn't you find Chansey? How to fit the gasket on the block, top or bottom, left or right, or how to do a whole 'change a headgasket' job? Report
June 11, 201115 yr comment_531139 yeah just did mine cos it overheated, blew the gasket and warped the head :( then to top things off, the coolant went into the oil :( 1. remove inlet and exhaust manifolds, spark plugs, leads and dissy cap 2. remove two bolts and on the top of the rocker cover and remove rocker cover 3. remove rocker gear 4. in opposite, diagonal order, remove the cylinder head bolts 5. pull off cylinder head 6. remove and discard gasket and check block and cylinder head for warping 7. (optional) remove and regrind valves into seats 8. install cylinder head with bolts in opposite diagonal order to correct torque (if u can get the bolts in corrent order from a book then thats better 9. install rocker gear, 10. install rocker cover 11. install spark plugs, leads, dissy cap, and manifolds 12. run engine till operating temp and then adjust tappets thats the very basic process that i did and it worked a charm :) good luck Report
June 11, 201115 yr Author comment_531214 Those pictures you posted, are they out of a gregory's manual? thanks for replies guys btw. Report
June 13, 201115 yr Author comment_531747 Hey guys just wondering a)Torque settings for head bolts? b)Anyone un-common sized sockets ill need or uncommon tools? Report
June 13, 201115 yr comment_531756 best bet is to grab yourself a gregories manual mate. all the torque settings will be in there. actually if i recall correctly, last time i bought a headgasket for a 4k (ACL i think) it came with the torque sequence and settings in the packet. i changed a 4k headgasket with a basic socket set, no weird sizes required. Report
June 14, 201115 yr Author comment_532025 Hey thanks i had a look at the gasket set and i got the torque settings cheers for that. this forum is so much better then a commodore forum haha. Report
