November 11, 200520 yr comment_82235 just wondering if a ke55 gearbox bolts to a ke70?Do i need to change anything? thanks Edited November 11, 200520 yr by COROLN Report
November 11, 200520 yr comment_82250 you need to change the tail housing as the ke55 rear housing is different to the ke70, different mount and gearshift position. Report
November 11, 200520 yr comment_82254 ke30/50 to ke70 extension housings are different in the shifter linkages, so in a word, no it doesn't fit. unless you cut a hole in the floor Report
November 11, 200520 yr comment_82257 If you change the extension housing, it will work fine. I have a 5 speed out of a KE70 in my KE35 Report
November 12, 200520 yr comment_82328 yip just change the rear housing and it will be ok to use. Report
November 21, 200520 yr comment_83495 i need to do that as well 5 speed ke55 gearbox swapped into a ke70 i hope that its not to hard Report
November 21, 200520 yr comment_83505 Nothing's hard if you don't mind getting your hand dirty :jamie: Just expect a little fun.. as you would with all projects :paw: Report
