Hey guys,
I got a ke70 a few weeks ago, everything in it is all sweet exept for this one problem.
If I have the car running or not and i press the brake pedal with the light stalk turned completely off, the cluster and the middle part of the console with the fan and air settings light up and also the parkers if the headlights are turned off.
And it seems to be drawing power to the brake lights aswell, you can just see the brake lights come on if you have the lights turned on.
I have checked fuses and wiring but i have no idea what the go is.
Any help is appreciated.
Cheers guys
Edited by 7rav
Also bought my Ke70 recently and have the exact same problem.. P.M. me if u figure out the problem, mate. :)
Does the brake light take the same bulb as the tail light, guys???
Cheers.
Cheers for the quick reply dbr11k.. but now I'm confused..
The rear light assembly has a socket for the indicator, tail and brake.. or at least that's my assumed order of the sockets.. At the moment, the brake and tail light sockets are using the same type of bulb.. What exactly do you mean by, "brake light and tail light are one"?
I guess, in short.. what type of bulb do I need to put in the tail light socket and what type of bulb do I need to put in the brake light socket? I'll go buy them ASAP, as i can't drive at night currently!!! :\
Sorry for hi-jacking ur thread, 7rav but i assume I'm helping your cause.. haha :)
Much appreciated guys.
Peace
The code for taillight bulbs is bay15d and what he means is that the brake light has two parts to it internally. One fillament goes on for lights and another extra one will go on when brakes go on. in a ksev there are only three bulb holders ,reverse light, brake and indicator.
Brake and tail are one bulb with two filaments.
Tiny 6watt or so for tail light, 25watt odd for brake light.
Offset pins, so it must go in only one way... as dbr11k said, if you have the wrong bulb it won't sit on the contacts properly.
Check the earths to the body too, there's one by the boot latch. Loosen them, wiggle them, tighten them up.
Sorry guys.. Can't believe I didn't realise the 3rd socket lines up to be the reverse light.. hahah Awkward! O.o
Changed the bulb to a dual filament in the middle socket and all is a go now! :D
Hope this helps you 7rav!
Thanks heaps, gents.. been a big help!
Peace out..
Peace out..
Yeah its all good now, I opened the back lights up, one had the 2 fillament bulb the other one had the single fillament so i replaced it and i works like a dream.
Cheers dbr11k you helped alot
thanks guys :y:
