phil86 Posted September 17, 2011 Report Posted September 17, 2011 1. What is the standard sway bar size on a ke30? 2. Where can I get a strut brace? Quote
Evan G Posted September 17, 2011 Report Posted September 17, 2011 standard front would be 19mm, on late model ke55 have 21mm (ones with square headlights) Quote
K&S Posted September 17, 2011 Report Posted September 17, 2011 My ke55 doesn't have a rearswaybar Quote
Evan G Posted September 17, 2011 Report Posted September 17, 2011 is a sqaure headlight? 1981 model? Quote
phil86 Posted September 17, 2011 Author Report Posted September 17, 2011 Round headlights ke30 1976 model, I wanted to know the front swaybar, sorry for not specifying. So the front is 19mm? Quote
silverra23 Posted September 17, 2011 Report Posted September 17, 2011 Cusco make strut braces for TE37's, which are the fancy version of the KE30. I got mine from www.ajps.com.au He can also get camber strut tops for them, but they only really work if you are running coil over shocks. Tell him Adam sent you :) Quote
TarmacAttack Posted September 17, 2011 Report Posted September 17, 2011 I was thinking of making my own strut brace from a cheap ebay one i have here from a subaru.. Trim it down, redrill the strut top bolts and weld it up Quote
Dave71 Posted September 19, 2011 Report Posted September 19, 2011 Cusco make strut braces for TE37's, which are the fancy version of the KE30. I got mine from www.ajps.com.au He can also get camber strut tops for them, but they only really work if you are running coil over shocks. Tell him Adam sent you :) thanks youre a champ! Quote
greenmac80 Posted September 23, 2011 Report Posted September 23, 2011 also for custom swaybars check out selby's i got 2 prices.. 24mm custom bar was 195+12freight and 22mm blade adjustable was 212+12 freight. also btw late 55 and ke38 have 22mm not 21mm Quote
