Everything posted by K&S
Old School Show'n'shine Morayfield 1St February
oh really? well ill definantly be keen for the next one
should we try get a few corollas together for a bit of a line up next show? whattya rekon reed?
I drove in as you drove out reed, I was in the white ke55 with front lip n roof racks
$500 Ke55 Coupe Project
oi your naths mate, I got him on instagram, seen he posted a pic of this or he liked it or something, interior looks pretty neat, will be good to see what ya do with it
23Rd September, Jap Lakeside
i will definantly be there as it is just 15 minutes along the road from home
anyone heading out to lakeside raceway on the 23rd of september for the japanese day?
86 Vl Sedan $2000 Ono
i have a blue vl sedan, has a decent sound system, 28 spline disc brake lsd, 18's with good tread, neads a bit of work has rust in the boot n around the front windscreen, $2000 open to swaps text 0422674187 for pics Scott.
Lower Control Arm Length And Neg Camber
Azzy_10, I didn't in my ke55 with gh sigma arms, still got heaps of thread to play with
yes i found this with mine, toe is a bit excessive but its needed with the camber n handles way better
i got gh sigmas in my ke55, gives a tough stance, nothing to major but still what i aimed for
Diff Not Centered
this made me laugh, my diff in my ke55 actually sits 5 to 10 mm to right, but i do beleive it is because off the blocks n the u bolts need a loosen n kicked to the passenger side
Tie Rod/tube/ke70/ke3x/5x Faq
Put the gh sigma arms in my ke55, all I had to do was drill a new hole for the swaybar link pin and grind down the lca inner bush to make it thinner, didn't need to use ra celica tubes, quite effective outcome with 2 degrees of camber each side
will ra65 tie rods have enough length to wind the toe out? or will i have to find ra40?
Mazda 808 Wagon Totally Rust Free
Is this sold?
Our 7k
I have a 7k in my ke70, I'm having some troubles with getting it running right, I'm just using stock 4k carb n manifold, would I need a bigger carb to compensate for the bigger engine?
7K Into My Ke70
Or how do I work with it if the 7k dizzy has n inbuilt igniter, I heard it's inbuilt
7K Into My Ke70
What's needed with the distributor side of things? Can I use the 7k dizzy n get a coil n igniter n hook it up or what?
Sway Bar And Strut Brace For Ke30?
My ke55 doesn't have a rearswaybar
4K Spigot Bearing
I just bought one it is 6001
7K Engine
I just need to get my néw clutch n then the transfer will be going down :)
7K Engine
Oh really? Gavclassic rekons I have to use the 7k starter
7K Engine
I got one :) I need a 7k starter motor tho the rest of the shit off the 4k bolts straight on apparently, fuel pump, intake, has electronic dizzy, just need a starter
I'm putting gh sigma arms into a ke70 just thought id add that
Referring to first post can I use xt130 tubes with ra40 tierods?
7K Engine
So does anyone have one for sale, I got the wreckers looking across hotline for me
