Tomas_90 Posted November 10, 2011 Author Report Posted November 10, 2011 The bolts are worth a check-up. What is it that i could do to fix this then? Are there some bearings or something in the diff that could tighten it up? Or is the entire diff shot? Quote
Trev Posted November 10, 2011 Report Posted November 10, 2011 Heh, well fair enough :D The rear driveshaft that goes into the diff is rocking about 1 - 1,5 centimeter. That could mean a problem :D If the diff flange is moving 1 - 1.5 then it is just diff backlash which is adjustable to an extent, if the previous owner did the UJ's then there is a good chance that he put the flanges back on 180 out which will most of the time cause a vibration. Quote
Tomas_90 Posted November 10, 2011 Author Report Posted November 10, 2011 If the diff flange is moving 1 - 1.5 then it is just diff backlash which is adjustable to an extent, if the previous owner did the UJ's then there is a good chance that he put the flanges back on 180 out which will most of the time cause a vibration. Okay. So how do i adjust that? Quote
Trev Posted November 11, 2011 Report Posted November 11, 2011 Okay. So how do i adjust that? Take it somewhere if you are worried about it as there is more to it then just tightening it up. Quote
Tomas_90 Posted November 18, 2011 Author Report Posted November 18, 2011 Been driving the car now for 2 days to work and back and there is indeed quite a lot of vibration. You can't feel a thing of it until you hit 55-60 km/h and then all the way up to about 100 as said. It was the same in 3rd and 4th gear so i doubt it's the gearbox, and i would like to believe it comes from somewhere in the back when listening from inside the car while driving. Haven't looked any closer at the driveshaft yet. Quote
altezzaclub Posted November 18, 2011 Report Posted November 18, 2011 Haven't looked any closer at the driveshaft yet. No rush.. the loose bolts will drop out or the UJ collapse and when the driveshaft drops out the car could pole-vault over it. Should be an exciting ride! Quote
Tomas_90 Posted November 19, 2011 Author Report Posted November 19, 2011 Oh it'll hold. It's a Toyota! Quote
Tomas_90 Posted January 17, 2012 Author Report Posted January 17, 2012 Right, small update. I've looked under the car and as far as i can tell everything seemed fine exept for the rubber bushing support that the driveshaft goes through under the middle of the car. It seemed dry and made a "dry rubber, cracking" sound when moving it. You could move it a cm or 2 back and fourth, but the driveshaft wasn't really loose. Could this be related to the issue? To me it seems a bit too small of a problem to cause the vibrations, but i don't know.... Quote
Trev Posted January 18, 2012 Report Posted January 18, 2012 Yes, a worn centre bearing can make the shaft bounce around. Quote
altezzaclub Posted January 18, 2012 Report Posted January 18, 2012 Yesterday I headed of with a mate to load his early 90's Landcruiser with gravel... It made a very distinct 'ting ting' as he let the clutch out, and he said it has been making it for a month now. When he parked it I grabbed the d'shaft. Solid as a rock. Same thing going home loaded, so when it was empty I said to park it level with the handbrake on & out of gear. "Oh, the handbrake is useless (on discs!) and I always leave it in gear" Once we had it sitting freely the driveshaft was loose in the UJ, and once we had it off the pinion flange is loose with a little oil leaking out. $28 for a new UJ, we stripped it but I've asked another mate to press the new one in, and I'll tackle the pinion after lunch. Tomas 5mm will cause a terrific vibration, less than that will especially if it is a "loose" movement and not damped. The d/s should be firm in the rubber coupling and any movement should involve crushing the rubber. Either replace it or get it looked at. The driveline garage will check them all. Quote
wicky Posted June 29, 2012 Report Posted June 29, 2012 Hi All....my KE 70 having the same problem as i accelerate over 60 kmh...i changed 1 of the UJ on rare end of the drive shaft 1 month ago...vibration slowed down but not completely finished Also, its vibrating when i pushed the clutch at high speed like 70 to 90 kmh Quote
B.L.Z.BUB Posted June 29, 2012 Report Posted June 29, 2012 Check the center bearing of your drive shaft. Quote
wicky Posted June 29, 2012 Report Posted June 29, 2012 Check the center bearing of your drive shaft. there is no center bearing ....its a one piece drive shaft Quote
