December 12, 201114 yr comment_571067 hey agan i have had no luck in getting my 4age running thats in my ae71 i wos giving a old ae82 i think? with a 4ac in it carby motor. i know i will have to change fual pump back to a low pressher,that i will have to change the frunt half of the exhurts system.i just wont to know if the water pump of the 4age will bolt onto the 4ac?? or will i have to leave the pump on and addapt a water system to change from frunt wheel drive to rear wheel drive. after i get car going and regod i will be looking into gaskets for the 4age and the carby set up and a 6al for spark. so i can do away with the injecton system becuse man i have wiring!! so yeah any info on the frunt wheel drive motor into a ae71 wood be nice thanks. Report
December 12, 201114 yr comment_571070 apparently the front wheel drive 4ac engines didn't have the holes tapped for the engine mounts. Which isn't a hard job really assuming the holes are already the right size Report
December 13, 201114 yr Author comment_571361 ok well i can drill and tap the holls out to sute. hope thats all i have to worry about Report
December 14, 201114 yr comment_571436 ʞ©$ɟ! Please, for the sake of other users....SPELLCHECK! Report
December 14, 201114 yr Author comment_571496 mate i spell cheek every post! so like i have siad befor sorry, my typing is ʞ©$ɟed but no need to be a ʇ~~ɔ about it. Report
December 14, 201114 yr comment_571531 i know i will have to change fual pump back to a low pressher,that i will have to change the frunt half of the exhurts system.i just wont to know if the water pump of the 4age will bolt onto the 4ac?? or will i have to leave the pump on and addapt a water system to change from frunt wheel drive to rear wheel drive. ok well i can drill and tap the holls out to sute. hope thats all i have to worry about mate i spell cheek every post! so like i have siad befor sorry, my typing is f***ed but no need to be a c*** about it. I don't mean to be a Spelling Nazi, but in what spell check program do these words exist? :hmm: Edited December 14, 201114 yr by carbonboy Report
December 14, 201114 yr Author comment_571569 i use spell cheek with every post as i don't wont to be harassed about my spelling,bad grammer. i did use spell cheekand it did not change them words for me so stuffed if i know sorry! Report
December 15, 201114 yr Author comment_571697 no I'm born a bred austalian 27 year old that failed with school work becuse of my broken home.i relly am working on this.but this post is not about cars back on topic mybe? Report
December 15, 201114 yr comment_571717 So back on topic, the water pumps are in the same physical location & have different outlet housings/directions depending on whether or not they're FWD or RWD items. Whether or not a carby pump will bolt up to a fuel injected engine or vice-versa, I don't know, having never tried it. In theory it should. The 2AC & 4AC (FWD) pumps are throwing up the same part numbers but are different to the 4AGE (FWD) item. These part numbers are different again for the RWD 4AC & 4AGE. Having said that, you could just find some correctly shaped hose to suit (annoy the person at your local auto-parts store to go through hose catalogue, take measurements first), but according to an old thread on ae86dc it's not worth it. This may be handy though, scroll down to the '4AGE Water System' section, there's some handy info there on pump differences. http://www.billzilla.org/4agstock3.htm Report
December 15, 201114 yr Author comment_571736 So back on topic, the water pumps are in the same physical location & have different outlet housings/directions depending on whether or not they're FWD or RWD items. Whether or not a carby pump will bolt up to a fuel injected engine or vice-versa, I don't know, having never tried it. In theory it should. The 2AC & 4AC (FWD) pumps are throwing up the same part numbers but are different to the 4AGE (FWD) item. These part numbers are different again for the RWD 4AC & 4AGE. Having said that, you could just find some correctly shaped hose to suit (annoy the person at your local auto-parts store to go through hose catalogue, take measurements first), but according to an old thread on ae86dc it's not worth it. This may be handy though, scroll down to the '4AGE Water System' section, there's some handy info there on pump differences. http://www.billzilla.org/4agstock3.htm thanks mate il cheek it out il fined out soon wen i pull both motor out and start swoping shit over Report
December 15, 201114 yr Author comment_571737 Australian* thanks for your input! yes i did meen australian.thanks for waisting your own time having to comment on my post. Report
December 15, 201114 yr Author comment_571739 well thear you go my spell cheek don't change my mistakes even wen i change them y wood it do that? Report
December 15, 201114 yr comment_571808 mate i spell cheek every post! so like i have siad befor sorry, my typing is ʞ©$ɟed but no need to be a ʇ~~ɔ about it. Sounds like your using the "Austra-Asian" spell check. PM me your address and I will kindly send you a dictionary :wink: Report
