January 20, 201214 yr comment_578983 Hey guys, Just wondering if anyone knows about ke20 front stud pattern conversions. I currently own a ke20 and the previouse owner has done a 4x114.3 conversion on it. I need to know what is normally changed, (struts, hubs, lca's??) because i need to raise the front up a bit for RWC. Thanks heaps Matt Report
January 20, 201214 yr comment_579007 I'm guessing factory struts just either ke30/70 hubs bolted to the to brakes or someones converted it to ke30/ke70 brakes If you get some pics up i can confirm for you Report
January 20, 201214 yr comment_579030 The struts stay the same, so you will still have ke20 springs and shocks at all 4 wheels. Report
January 20, 201214 yr Author comment_579134 Kool thanks heaps. That helps heaps. Ill get a photo up soon to see if you have any idea on what brakes they have used. Cheers Matt Report
January 21, 201214 yr comment_579308 Can be anything from hubs, to hubs and discs, to full struts really. Report
October 16, 201214 yr comment_631999 Hi,I'm also trying convert 4 x110 to 4 x114.3.In front can use ke 30 or 70 studs with discs.But don't know whether the break without booster in ke20 may need to upgreat or not.But what about rear? Report
