January 31, 201214 yr comment_581383 G'day i'm just about to go about doing the diff on the ke10, it's a jap diff and it could be an auto ratio because the car was auto originally. I'll be putting in ke30/55 jap axles for the 4x114.3. I'll be running a k50 along with it and in my experience i've always found the k50 to be pretty short in the gears for my liking, so i was contemplating swapping in another diff centre while it's apart to lengthen it out as much as possible. Now does anyone one know A; A stock ke10's diff ratio, and B; The lowest Ke diff ratio i can swap in and if it's worth it Any info or advice would be Overrated, Cheers! Edit. Oh For Fck Sake M.I.N.T >| :lolcry: Edited February 2, 201214 yr by Jono.C Report
January 31, 201214 yr comment_581390 The k motors short ratio's are good. you'll still sit around 3 grand on a hundred unless you go long in which you'll sacrifice any performance in the name of economy. I've got a '00 Holden Ashtray 1.8L 5sp for example.: 1st-long 50kph, 2nd-short 80kph, 3rd-short 120kph, 4th-short 160kph, 5th-long 210kph :cool: . @ 5,500rpm peak changes. Yet 100kph in 5th gear is 3000rpm The '04 Camry Tivo 2.4L 5sp for example: 1st-short 40kph, 2nd-short 80kph, 3rd-long 160kph, 4th-long at 200kph and haven't been past there..... 6000rpm peak changes :o but still 2900rpm at 100kph in 5th. YOU WILL USE HOW MUCH FUEL WE TELL YOU TO USE!!!"Oil Barons..." Edited January 31, 201214 yr by GJM85 Report
January 31, 201214 yr Author comment_581408 What did the 3.7 come in? Well my torque will be down low to mid so i'm in now real hurry to hit top end, might interested in it pulling hard through the gears and them being more usefull Report
February 1, 201214 yr comment_581500 3.7 is rare. not sure what they come in but i managed to pick one up last year in a bulk purchase. think 4.11 is man and 3.9 is auto. correct me if wrong. suggest sticking with auto ratio and if you really hate it then change it. matt Report
February 1, 201214 yr comment_581528 Is that correct? My '30 had a 4.3 in it. The auto's might have been 4.1 but I couldn't be sure on that one. I think 3.9's and 3.7's are going to be hard to come by in the jap size. Report
February 1, 201214 yr comment_581529 According to the owner manual, KE1x final drive was 4.222 in the sedans and presumably coupe, and 4.444 in a wagon. No mention of any variation for an auto. KE2x was the same, with additional info that the 4.444 was optional in a sedan. A later owner manual notes that the 4.444 was found in Toyoglide sedans & coupes. There was a 4.1 in the 1400cc which presumably you won't find here. Report
February 1, 201214 yr comment_581553 According to the owner manual, KE1x final drive was 4.222 in the sedans and presumably coupe, and 4.444 in a wagon. No mention of any variation for an auto. KE2x was the same, with additional info that the 4.444 was optional in a sedan. A later owner manual notes that the 4.444 was found in Toyoglide sedans & coupes. There was a 4.1 in the 1400cc which presumably you won't find here. :yes: they had the B series jap 5.7" diffheads. U-series 6" jap diffheads will fit in housing and on axelsplines tho. They came in late kp61 (3.4/3.5), late ke2, ke3 and ke7s. also AL25? More ratios available than the B-series. Australia however had borg warner diffs in later KEs, don't know from exactly when. Report
February 2, 201214 yr Author comment_581717 So what kinda of options, this being said do i have for getting a bit more use out of the gears? What'd be the lowest (obtainable easily) diff centre to grab? Report
February 2, 201214 yr comment_581803 maybe grab urself a sigma diff i think 3.4? some people been using them in speedway not sure what model tho Report
