Camber Plate Studs
Heyo. Turns out my camber tops I bought don't come with studs as they reakon you use your existing ones.
So where would one go to locate such studs suitable for camber tops? I don't mean some dodgy bolts from k&d I want the proper studs
Thanks!
Is that a local store near you or an online type deal?
Haven't heard of them before which would suggest Tassie might now have one
If you see the photo in my thread they're blank/ universals so you drill your own holes. I'll be getting an engineer to do mine though and the press studs in
I've had a thought. I have a pair of ke70 factory strut tops. Are the studs removable from those that i can use for my camber tops?
Nuts & bolts is the tassie equivalent. Make friends with them. :yes:
