New pickup coil, rotor, cap. Now I get nice blue spark.
Starter fails.... fresh battery and its slow cranking not enough to fire engine.
New starter, only clicks. I cleaned all grounds and cables and battery connections. Now you can here it spin, then click but it's not engaging the flywheel.
My guess is the starter is bad, its a refurbished one so maybe i got a bad one, ill take it to the store and swap.
  • Replies 43
Bad starter, got another 'new' one and....she fires! Then dies and wont start again..... :bash: Now I'm getting no spark at the plugs again but the msd is sparking just fine. Does anyone know how to test the pickup coil? Should there be more air gap than stock with MSD?
Pickup coil was fine after testing two others from the store, all in range of 130-160 ohms restistance which is fine.
Found the starter not cranking fast enough due to POS from parts store, ordered another one, they tested it before i took it and it was bad too, ordered another one and we have turnover! That's 4 starters!
Engine spinning fast enough now we have spark! Hooked up MSD again and she wanted to fire but the oil from the UNI filters clogged the carbs. Carb cleaner soak and waaalaaaa! She lives again!!!! Back to getting the cam and port and polish head with valve springs.
Had fuel problems, dumped fuel cell and found the 1 small filter to be way dirty. Then I grabbed 2 more filters and I'm going to clean out the cell then we should be good.
ripped the fuel tank out...
rusted inside and paint peeling on the outside
sanded and coated with 2 cans of truck bed liner spay
added some red for contrast
and done! new bolts and filter too!
brakes pulling to the left, found that when I did them last year I got one brand new rotor and had the other turned which caused the left one to be thicker thus grabbing first. So I put some drilled slotted rotors in.
  • 5 weeks later...
Well its been awhile but the updates are...
Wired a relay panel with a new switch panel ( See thread here! )
Wired up a new Tach that has oil pressure, water temp, volt meter, all in one.
Covered up all wires in split tubing.
New battery.
Painted steering column cover, prepped dash for sticker bomb assault
All windows tinted, front and rear glass in with new gaskets
Needs for soon:
Install 5 point harness
Fix fuel leak
Install dash panel and mount switch panel
Drive it...she is calling to me...
  • 4 weeks later...
Ive been kinda busy...
wiring,
tidy up the engine bay and new wires,
sanding, painting,
spraying,
Travis from work actually took over this point, since I have never done it, but was going to learn....good or bad....
Turned out TITS! It looks like a car now! So I put the glass in with Taiwan rubber. The back quarter window seals are impossible to find so I just took some door seal off a Ford E450 van/truck and it works perfectly! Cut to size and it seals and looks JDM.
Today I got the kill switch wired correctly, turning off the car. You have to get a 4 pole switch and interupt the main power and the Field wire from your alt. I'll put the details in my wiring thread.
Also got all the black rims on the same set of tires, I have 1 gold and 1 black set and they were mixed. Got an alignment done up she hugs all the turns. Aug 4th is my first Autocross practice so we'll see if she comes back in one piece.
One more but at night, a little hard to see but thats the matte black absorbing the light...
