Hi Everyone,
i previously worked on my AE92 and unfortunately had to be sold to allow something esle to prosper..
Previous AE92: Click Here
anyway in january i made the aquisition of an AE94 with a 4AFE...the car had not been run in over a year and was sitting there.
needless to say some work had to be done before putting it back on the road. didnt put rego on until late February..
luckily for me, it had some light mods already made to it;
- Black Window tint
- 16In Rims
other than that the car is pretty much stock..but the previous owner got paint happy and paited bits here and there white..
so thats gotta change asap.
Photos below;
Edited by Hans
  • Replies 31
so anyway,
first things first..I'm not a big fan of 5'Inch fulli sick tachos.. so i went OEM and replaced the factory Speedometer with one that has a tachometer.
Now yes, it is a straight Swap..
BUT i would like to point out, many people who have tried this has had some degree of issue within that process.
upon installation all the gauge intruments will either not work or you will see funny things like the temp gauge on "overheat" etc..
Make sure that original speedometer is replaced with its "right" replacement.
I went to my local wreckers and sourced a Speedometer that has a tacho in it. its a "174" series
upon plugging it, the speedo was partly not working and there was some funny readings as mentioned above..
now I could either re-wire all the plugs to match the new unit..(but since I'm feeling Lazy this arvo..
I could just go back to my local wreckers and source out one that is of the same series of the one i am replacing. (which i did)
the exisitng Speedometer in my car was a "357" model and the speedo i sourced was a "356" model
refer to photo below;
swapped over and working well!
while i had the dash undone..i installed an OEM clock as well..which read "LOL"
i didnt like the previous "fulli sick" white painted mirrors (which were also cracked and replaced them with OEM black ones.
that was it for today..not as exciting as an engine swap..but it kept me entertained smile.gif
Body wise, these are next on the list;
- New Front Bumper (Black)
- New Rear bumper (Black)
- New headlights
- New Grill with Toyota Logo
- Fog lights (yellow)
- Recondition & respray wheels to Gold
- Cut & polish Detailing
Edit 14/08/2012
Next up was the bucket seats...i had forgotten what a pain it was to modify factory rails...but it had to be done :P
gave it a good cut and polish and installed some yellow foglights..and updated the grill.
then of course gettin carried away with ideas..
but no..i do believe a better bottom end would be required..so i got myself a 7AFE
How to build a 7AGE
Uploaded with ImageShack.us
all in due time of course..
next up is body styling..the car has seen better days..it had a respray job so the paintwork is good..but it is all in the small details. for example the headlights and taillight have "aged" and even after cleaning them thoroughly they looks "old" and weathered..
so as previously mentioned. i will be going with black bumpers and in the process, i will be adding new headlights and tail-lights to give it that "new" clean look
anyway before all that occurs..this is what the car currently looks like..
Update 15/08/2012
so anyway the parts arrived and i got busy..
and dismantling the front end began..
See the difference with the headlight and how the previous one is weathered?
and there you have it..i only got the front end done today..might do the taillight and rear bumper on the weekend..
unfortunately it was getting dark so the after shot doesnt do it justice..i will upload new ones when it ake photos during the day...all in all the front end looks brand new :)
Update 16/08/2012
Today i updated the back end with new tail lights ans a new rear bumper and got rid of the previous tail light trim which was painted black from the previous owner.
I will be respraying the center part black over the weekend maybe if time allows..
currently for comparison from before, could do with a detail in due time :)
Update: 18/08/2012
I just realised i don't have a shot of the interior..i'm still working on it.. gauges to go in the center (nothing fancy just SPECO voltage, water temp and oil pressure)..currently empty;
Some shots of today's completion of the rear end with the space between tail lights painted black;
13/09/2012 - Updates
As at today! just the basics that had to be done..
- Replaced Brake fluid
- Replaced Clutch fluid
- Coolant Service
- Machined Brake rotors + new brake pads.
- 16x7 Vault Wheels with Federal SS595 tyres (low profile - 40)
the the ricey mods of course..
- Painted calipers and drums with high heat red paint.
Update 26/09/2012
and so thou shall have 20 Valve and ITBs!!!!
Since i am swapping the 4AFE (1st gen) to the 4AGE 20V Silvertop, i have to splice into the under dash harness of the AE94 as i don't want to change the whole harness (too much work)
the 20V ECU(the one i haveis for automatic transmission) has three plugs, two of which connects to the Engine Wiring Harness and the remaining one is a 22 Pin plug for the under dash loom.
with the 4AFE the under dash harness plug that connects to the ECH is a 16 Pin, so i have to splice into the initial 20V Plug to match..
the photo below might come in handy to those in need of it, so I'm sharing it;
Under Dash Harness 4AFE to 4AGE 20V SIlvertop AE101 ECU Pinout; all it means is i have to solder/weld into the 22 Pin Plug for the 20V ECU;
Update 17/10/2012
Not much has happened in regards to the engine swap...i will need a new clutch and drive shafts as the existing ones are nearing the end anyway..will have to acquire these first..
but in the meantime..
- Front Lip Added (Old School Mazda 626 Lip)
- Tail Light Extension added (may as well..looked a bit plan :P)
Wow..it actually looks nice than before i said! do you agree?
it starting to look nicer that my WRX lol!!
Edited by Hans
Update 30/10/2012
Everything around the engine is disconnected, driveshafts out!..
i didnt undo the gearbox..will try to get both out in one go..its gna be a mission...
but at the moment there is only one strategy to get it out.."Wiggle Wiggle Wiggle, Wiggle, YEAH!"
more to come..
Update 7/11/2012
this is what i am up to..
4AFE & C50 Gearbox out:
then of course, i cleaned the engine bay from the oils and what not with the degreaser..
Fitted the C52 gearbox + Drive shafts:
next up..i have to get my 20V Flywheel machined before i drop the 4AGE in smile.png
Got the flywheel machined this morning and fitted the clutch on.
frankly i think bolting the gearbox on the motor then drop it all in at once is the best way as it is easier.
I am really struggling to get the motor in due to limited clearance. so this afternoon i had to undo it all and will continue tomorrow..(will drop the motor and gearbox as one.)
from this point onwards i guess i am on the home strech and hopefully everything bolts up haha, then after that its just wiring.
EDIT 8/11/2012:
- Took Driveshafts out
- Took Geabox out
- connected gearbox to the motor...what a pain to get it to line up!! - had to get a mate over to give me a hand..but all is good now;
i got lazy this weekend...so i fell behind a bit,
spend most of my time with the mounts..and connecting things up..
then radiator..i didnt get around to the driveshafts..etc..but progress in little amounts are better than no progress at all...LOL smile.png
as at 11/11/2012:
Edited by Hans
  • 4 months later...
its ridiculous how time flies nowadays with work and uni and what not, updates added :)
will try to add multiple updates this month..will be installing parts etc..
Edited by Hans
Good work Hans, looks like a very tidy ae94.
The white bumpers don't look too bad, however I'm sure it'll look good none the less with back ones.
With the 7afe, is there much fiddling to do with electronics that was for the 4afe? Such as engine bay looms and computer, or is it plug and play? Also what about the powersteering? They have a different hard line compare to the ae94 type which runs above the drivers side chassis rail.
don't know whether your particular about the odometer, did you know you could swap the csi odometer/guage assembly into the csi limited tacho cluster? Recently I did this as I wanted a change but wanted to retain the original kms.
Edited by Ben-89
Nice sedan!! :D
Just a tip on the motors, if you want speed don't bother with the FE heads... get yourself a 4AGE head to pop onto that 7A bottom end ;)
Good job man, keep it up
Updates added 15/08/2012~
thank you, much appreciated :)
the main reason i acquired the 7AFE was for the 1.8L Bottom End, i plan on eventually going with a 20V head..and build a 7AGE with a Haltec ECU..but all in due time.
the 7AFE to 4AFE is not a straight swap..everything will bolt up but the wiring is not plug and play...its a whole new conversion...
slowly but surely i will build this engine...but for now the 4AFE is great for running around town :)
as for the odometer..i've done it all before..couldnt be bothered with this one..there was only a 20,000kms difference.. the new odo i put in shows 20,000 kms extra..no big deal i guess.
i actually have a write up about swapping the speedo gauges to retain orignal kms in my old thread...
http://www.rollaclub.com/board/topic/34123-hans-ae92-sedan/page__hl__yuvi
Nice sedan!! :D
thanks man!!
i think ive pretty much answered this one with the previous quote :)
20V 7AGE is the plan.
Minor Update 18/08/2012;
I painted the space between the tail lights black, now i need to find some gromets to plug the holes left behind..
Thanks for all the positive feedback!! :)
as for the 7AGE build, which I'm trying to simplify in order to make this into a swift and easy build (hahaha who am i kidding? :P)
this car will be my daily when I'm done with it.
Engine Plans are as follows;
- 4AGE 20V Frontcut
Bottom end:
-7A Engine block (Stock 7A Crank, Stock 7A Conrods, 4AGE 20V Pistons, redline between 6,500-7,000 rpms) - If Future turbo plans (then get forged pistons and rods)
will swap the bottom end from the 4AGE 20V with the above bottom end.
- 4AGE 16V Timing belt / 130 teeth timing belt..
Misc; required outside of the equation for to get the engine running reliably are as follows
- Aftermarket ECU will be required because factory 20V ECU will have the 1.6L map and can't be reflashed.
- Aftermarket Fuel pump
that should be it for a 7AGE 20V build.
this is my starting point reference, i will update as i build and obviously there will be issues which i will come accross and post up.
for the time being the 4AFE seems to be holding up hahahaha
