September 20, 201214 yr comment_627822 Thank you for making this write up, i have done the same conversion as this to my new ke70, was also owned buy an elder lady, Peddel box was a pain in the butt, pnly problem i have came across was the nutreal start position start wireing, i cut the plug off knowing full well that the curcuit had to be bridged, but never matched the black and black together, i curreny have to start the car by bridging one of the red wires with the black wires ( i know strange) but i will be performing this tomorrow, so i can put all my center console back in and have the car back to starting by the key again:) great read Report
September 21, 201214 yr Author comment_627955 Glad you found it helpful. i curreny have to start the car by bridging one of the red wires with the black wires That is the neutral lockout from the auto box to stop you starting it in any gear. Bridge it permanently & forget about it. Report
January 24, 201313 yr comment_644953 i just done manual conversion but wines real bad would that be the radio? only wines under load 1st 2nd 3rd but 4th is sweet then happens in 5th aswell? Report
January 24, 201313 yr Author comment_644963 Layshaft bearings are worn. 4th gear is 1:1 ratio so it doesn't drive through the layshaft, so its quiet. Get another gearbox, its hellish expensive to replace layshaft bearings as far as I know. Report
March 12, 201313 yr comment_649967 hey guys. i currently have a 3speed auto ke70e and ive got a k40 gearbox with clutch, clutch cable, flywheel and pedal box. Will i have to cut a hole for the gearbox to fit aswell? :/ As far as i know from researching its a bolt in affair? excuse my noobness :) Edited March 12, 201313 yr by Ketogirl Report
March 12, 201313 yr Author comment_649998 Yes, you will. I fittted the 4speed to start with then swapped that for a 5speed later. I think both manual boxes are the same length, but the auto control hole is further back. Report
March 13, 201313 yr comment_650081 nice one, i might add this is very similar to a 4ac auto to man conversion. Report
August 12, 201313 yr comment_664469 Good read but having a bit of trouble with the wiring car wont start just a click like a dead battery tried jump starting to but still the same thing and my tail lights are on all the time any help would be gold Report
August 12, 201313 yr Author comment_664549 Neither of those should be affected by changing the gearbox. The only wiring involved is bridging out the auto lockout, and if your starter solenoid is clicking then you have done that corrrectly, and the other is getting the reverse light circuit working. Have you done anything else to the car at the same time? Was it all working fine as an auto? Report
August 12, 201313 yr comment_664551 Yeah got it runnig I think it might be brake lights so maybe something to do with the pedal box maybe dunno pretty stumped Report
April 17, 201412 yr comment_681340 awesome right up. I will be using this one next weekend and will check which cross member you use and post it up. cheers Report
August 6, 20206 yr comment_723977 This is great mate, thanks for taking the time to document it. I’m not really looking at manual swapping mine yet. But in another note what car manual do you use? Just an eBay spec one? Report
August 6, 20206 yr Author comment_723978 I bought a Gregorys years ago, but it didn't have wiring in for anything except lights, so I started on Google... Since then I've vacuumed up all sorts of data from the web and just use that. Grab any manual you can for basic stuff, then ask questions here! (you'll love the manual over the auto, so much quicker!) Report
