March 23, 201214 yr comment_592194 hi i am new to this site. i was wondering what engine should i swap into my 1974 toyota corolla that doesnt require cutting any of the frame or body? i live in america as i see many people are in the UK or australia... i would like an engine that comes stock with a 5 spd transmission. Thank you !!! Report
March 23, 201214 yr comment_592213 Check the Engine Conversions section of the site. Might crop up a few ideas... Report
March 23, 201214 yr comment_592215 How bigs ya wallet to start with!!?? The usual upgrades for a ke20 is keeping it k motor like 5k, then there is a step up to the 4age, then a step up from that is ca18det, Sr20det all these WILL fit without cutting the body at all, there is HEAPS of things to shove in a 20 just depends how much you wanna spend!!! Report
March 23, 201214 yr comment_592220 Take a page out of Oke020's book and just 2J the thing. Gotta cut the firewall lol, get a ta22 and put a j motor in it, fits and doesn't need firewall mods hahaha Report
March 23, 201214 yr comment_592226 Just put abitta sheetmetal around your feet and remove the passengers seat hahaha, that's how ghetto I am!! Report
March 23, 201214 yr comment_592227 Sheetmetal? We use ply and scotch tape where I come from hahaha Report
March 23, 201214 yr comment_592228 Oh shit ply..... You stepped it up, plastic and sikaflex FTW!!!! Report
March 23, 201214 yr comment_592239 Probably a 3T in the States, I doubt you will find any 5K over there. Basically any 4cyl under 2L, but you might run into brake cylinder clearance issues with some of them. Your steering wheel is on the wrong side! :laff: Report
March 24, 201214 yr comment_592271 Meanwhile back at the ranch.....:rolls: As per Altezzaclub, a 2T or 3T would be the way to go. You will need to source the correct crossmember and front suspension including struts, brakes and steering knuckles, but should be easy to find in the states. A 5 speed gearbox (T50 from a T series engine) bolts straight on, but I am not sure how readily available they are in the states. Later boxes T50 boxes have the gearstick located differently but easily managed. Note there are T50 boxes that bolt behind 4A/4AGE engines which won't bolt up to a T series engine. Jump on to 3TCgarage.com US based website with a wealth of knowledge on these cars and engines. Report
