4Age Not Starting Maybe Fluding ?
hey guys I'm new to this site
i just bough a ke with a 4age in
when i bought it it was running then 3 days later it wouldn't start i think its fluding because as soon as you turn it over these a really stong smell of fuel
but if any one got any idea i be really happy to listen ahah
really need get this sorted as I'm hoping to take it to prac on the 31
so if anyone could help or give me advise it'd be really good
Carbs or injected??
Only carbs flood as far as I know- but you will get a raw fuel smell from an injected carb if the plugs aren't firing.
From personal experience I can tell you that you get a raw fuel/flooding smell from low compression too! If there is not enough compression it can't ignite the fuel.
Go check that you have spark at the spark plugs then tell us exactly what you have on the motor and just how well it was running when it went.
Carbs or injected??
sorry injected
sorry don't no much about it as i bought it 2 weeks ago
when it ran it ran fine
backfired a fair bit after reving was like it was getting to much fuel
idled fine without hassle
i started it up one day and it ran fine i drove it up and down my street
with out any problems
i turned it off then the next day i went to start it and it started on a really weak idle sounded like it was fluded
anyways i went to rev it and then it stalled and hasnt started since it
also i have checked for fuel leaks none at all
