16bitcelica Posted April 10, 2012 Report Posted April 10, 2012 What I want to do is put the 7mge from my mx83 into my mx73 which I can do easily, but I would like to put a ford 5speed in instead of a w58/r154 also I don't really have the money to get a r154 lol. What I would like help with is what would I need to put the T5 into my mx73? What I've got is the T5 & a exedy HD clutch and the pedal box that the T5 came out of. Quote
Jono.C Posted April 10, 2012 Report Posted April 10, 2012 For the cost and stuffing around just go w58, a 7mge wont break one unless you're insanely rough and don't maintain your stuff Quote
16bitcelica Posted April 11, 2012 Author Report Posted April 11, 2012 Cheers for the info man :) Quote
16bitcelica Posted April 14, 2012 Author Report Posted April 14, 2012 Need some guidance, will this conversion cost more than 1500$ if I use the T5? Quote
SLW42 Posted April 14, 2012 Report Posted April 14, 2012 Just cause you have something isn't always a good idea to use it man, put the t5 back into the falcon and use another W series box I.e w55 or 57 from a hilux/Celica, plus I'm very sure the cressy's will use a hydraulic clutch which is a lot less mucking around then making a cable clutch setup work You would need to find someone to make a bellhousing for it either using the t5 bellhousing then cutting it and welding it to a w series bellhousing or vice versa.... Save some coin and get a w box soooo much less work involved, or sell the t5 setup to someone looking for a manual conversion for their ea-el falcon and make some money to put towards the cressida manual conversion Also why do you want to use a 7m in an mx73 when a j motor will go in just as easily? Quote
16bitcelica Posted April 15, 2012 Author Report Posted April 15, 2012 Just cause you have something isn't always a good idea to use it man, put the t5 back into the falcon and use another W series box I.e w55 or 57 from a hilux/Celica, plus I'm very sure the cressy's will use a hydraulic clutch which is a lot less mucking around then making a cable clutch setup work You would need to find someone to make a bellhousing for it either using the t5 bellhousing then cutting it and welding it to a w series bellhousing or vice versa.... Save some coin and get a w box soooo much less work involved, or sell the t5 setup to someone looking for a manual conversion for their ea-el falcon and make some money to put towards the cressida manual conversion Also why do you want to use a 7m in an mx73 when a j motor will go in just as easily? Cheers for the input mate, you've got a decent point lol. 7m is coming out of my mx83 and I'm turning that into a slider with a 1j and thought instead of scrapping the 7m just put it in my mx73 :) Quote
Jono.C Posted April 15, 2012 Report Posted April 15, 2012 Put it this way w55 from celica $400 + off the shelf clutch Bellhousing $1000~ + clutch + fork + tailshaft etc Quote
white_sandshoe Posted April 15, 2012 Report Posted April 15, 2012 me and a mate of mine manualed an MX83. The MX73 is easier again. clutch pedal and master from an *A6* celica supra bolts up (it even has the holes pre-drilled to suit) and M-W5* bellhousings are friggin everywhere. any M manual will have a bellhousing you can use, since they are ALL interchangable. Sell the T5, do the W conversion, and have change left over... 5M flywheel and clutch work fine, but for less than $1500, my mate and I did custom 1 piece tailshaft, custom heavy duty clutch and all conversion gear... Quote
